Rear shock setup????? #801205 03/29/07 08:19 AM
Aaron84x4 Offline OP
I've almost finished putting on my Marlin 4" lift kit, but i've hit a little bit of a road block. When mounting my rear shocks i kept the stock spring hangars that were up on the frame, and mildly relocated the ones that were on the axle. Here is my current setup
(this is my 84 pickup (ext cab)) with the new shocks in the stock locations. The problem is that the shocks, now at ride height, are compressed with only about 4 inches of collapsable length left, as you can see
I'm curious as to better setups. Please post pics, measurements, etc!
thanks
<img src="/forums/images/graemlins/smile.gif" alt="" />
84x4 Toyota Ext. Cab Deluxe
Not enough hours in the day to do what i want.....
.....and sleep
Re: Rear shock setup????? [Re: Aaron84x4] #801206 03/29/07 01:57 PM
TexJeff87 Offline
Here's one... BudBuilt
I'm in the same boat...need to do this as well. Bud's thing is prolly the easiest. Others will chime in and tell me I'm full of beans.... <img src="/forums/images/graemlins/lol.gif" alt="" />
If Mad Max had a 4runner...
Re: Rear shock setup????? [Re: TexJeff87] #801207 03/29/07 02:44 PM
4Crawler Offline
Re: Rear shock setup????? [Re: Aaron84x4] #801208 03/29/07 03:06 PM
bkg Offline
Put the mounts where they are supposed to be - on the sides of the axle - and you'll be fine.
Brian K. Gallus
Re: Rear shock setup????? [Re: Aaron84x4] #801209 03/29/07 04:43 PM
Stevie Offline
Here's mine. Don't know what brand, but looks pretty simple/home welded.
[img]http://[image]http://i167.photobucket.com/albums/u145/Cavu2usf/Rearshocks022.jpg[/img][/image] [img]http://IMG]http://i167.photobucket.com/albums/u145/Cavu2usf/RearshocksTopmt.jpg[/img][/image] [img]http://[image]http://i167.photobucket.com/albums/u145/Cavu2usf/Rearshocksbottommt.jpg[/img][/image]
'80 4X4 Longbed
Re: Rear shock setup????? [Re: Stevie] #801210 03/29/07 06:35 PM
Staceman Offline
Check out the rear shock set-up available at budbuilt.com.
I home fabbed mine, using this style set-up.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6114 MB (Peak: 0.6823 MB) Data Comp: Off Server Time: 2026-07-14 12:36:38 UTC
