Slip Yoke Travel on front DS #801260 03/29/07 07:16 PM
Dingman Offline OP
So, I've changed the front springs on my 4runner which raised it quite a bit and as soon as I tested them, my front DS fell apart at the slip, too short now.
So, I measured up, got it lengthened, and tho it was close to perfect at first, the springs have settled a fair bit and now the dingin' thing is bottoming out (the slip).
Now, I can get the DS shortened again, but really the issue is not much travel in the slip.
What's the common solution to this? homemade square-tube driveshaft?
Paved Roads ~ Another example of wasteful government spending.
'85 $runner, lifted and locked.
See the Ding_yota here
Re: Slip Yoke Travel on front DS [Re: Dingman] #801261 03/29/07 07:47 PM
4Crawler Offline
Yep, either a square tube shaft or a longer travel slip yoke.
Re: Slip Yoke Travel on front DS [Re: 4Crawler] #801262 03/29/07 07:53 PM
Dingman Offline OP
I asked my local drivetrain shop and he said at least $250 to lengthen the slip yoke. I'll check around to see if any of my friends can build a square tube.
Re: Slip Yoke Travel on front DS [Re: Dingman] #801263 03/29/07 08:04 PM
Staceman Offline
Roger, give him the link to the axle relocation plates. This way he can move the front axle forward either 3/4" or 1". Cheap and simple to get you wheeling again.
Re: Slip Yoke Travel on front DS [Re: Staceman] #801264 03/29/07 08:05 PM
Staceman Offline
Given he has a crossover steering set-up.
Re: Slip Yoke Travel on front DS [Re: Dingman] #801265 03/29/07 08:13 PM
dcg9381 Offline
Check with any of the major fab providers for toyota - Marlin & All Pro - I believe one (or both) of them carries a long travel slip yoke that comes in well under $250.
I bought one and if I recall right, it's very simple to install.. You have to cut off the existing yoke, but it basically slides right end and you just weld it up.
22REturbo.net
1988 4Runner
Re: Slip Yoke Travel on front DS [Re: dcg9381] #801266 03/29/07 08:59 PM
OOP'S Offline
If you do it yourself make sure you phase it right and the d-shaft runs true.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Slip Yoke Travel on front DS [Re: Dingman] #801267 03/29/07 09:26 PM
missouriman Offline
is it the drive line or the dust cover.
dust cover is not so bad, if the drive line bottoms out it pushes the cap out of the end of the drive line any ways.
it is kinda messed up that that front moves closer on compression... vs the rear that moves away on compression.
I am looking at the square ag shafts....
also thinking about the 6 sided steel shafts and a 6 point deep well socket..
Re: Slip Yoke Travel on front DS [Re: Dingman] #801268 03/29/07 11:58 PM
eightyeight Offline
i cut down a rear driveshaft to make my front. stock slipshaft, maybee 6" travel. i have yet to drop it with my TG front springs.
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
Re: Slip Yoke Travel on front DS [Re: eightyeight] #801269 03/30/07 03:38 AM
Dingman Offline OP
Wow, that sounds like a good idea!!? I hadn't thought of checking the slip on a rear axle and - guess what - I have both the front and rear axles out of an '87 Toy pickup.
I'm gonna check that out! I guess I need to measure some more to see how much slip I need. One thing I've noticed while testing, is that my pinion moves up and down quite a bit. Is that normal and to be expected?
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6414 MB (Peak: 0.7612 MB) Data Comp: Off Server Time: 2026-07-13 18:28:57 UTC
