Tires or front end alignment #801541 03/30/07 08:40 PM
jeeperscreepers Offline OP
I'm in hopes someone has some knowledge or experienced this prob. before, The front end on my 1996 jeep grand cherokee lorado alltrack I just picked-up has a rubicon lift maybe six inch not sure bought it this way and ride hight is adjustable, my problem is while on the fwy it seems to float a little from side to side? the tires are mickey thompsons baja claws 33x12.5x15. I suspect the tires since the side walls are only a 2ply to my sureprise.
Re: Tires or front end alignment [Re: jeeperscreepers] #801542 03/30/07 09:34 PM
BigJim Offline
Somebody else will have to address your "floating" problem. I will say just about ALL tires are 2 ply sidwalls. No worries there.
Re: Tires or front end alignment [Re: jeeperscreepers] #801543 03/30/07 09:54 PM
BobRowe Offline
I've never used MT Baja Claws, but I did have a 1-ton truck (Dodge) with MT Baja Belted tires. It wandered really bad on the highway. I finally took them off and installed BFG Mud Terrain tires, and the wandering problem was completely solved.
BTW, the BFGs were better than the MTs on every surface (pavement, snow, rocks, dirt, etc) except sand, where the MTs had a slight edge. That was probably due to the wider cross section of the MTs.
Re: Tires or front end alignment [Re: BobRowe] #801544 03/31/07 12:17 AM
O
oldgreen Offline
Take a good look at the front track bar and make sure the bushings are not worn, if I remember right that causes a loose feeling on cherokees.
84 CJ7 304 HEI 35 BFG,s rear dana 60 with detroit locker,Viar compressor, fibreglass body, 2 1/2 spring lift, TF999auto, Warn 8000 winch, Plus a cool little trailer on 35,s. JEEP stands for just empty every pocket
Re: Tires or front end alignment [Re: oldgreen] #801545 03/31/07 12:36 AM
cuervo25 Offline
Isn't the MT baja claws bias ply, if so they are horrable on road and most likely the biggest part of your problem. Alignment most of the time will pull it to one side or the other,not back and forth. And the track bar problem is a death wobble definatly not a floating issue.
Bias ply tires do not have steel belts,instead they have nylon belts. in some ways that is great others it is bad. the good is the do great off road. the bad is that they squirm on the road, as you are feeling now. The tread also squeezes closer together on harder surfaces leaving less room in the grooves for water,snow,and so on to get in for better contact to road surfaces. If you switched to ANY steel belted radial i bet your problem would be gone
Re: Tires or front end alignment [Re: BobRowe] #801546 04/02/07 06:32 AM
Thanks everyone for the info I will look into changing the tires. <img src="/forums/images/graemlins/patriot.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6091 MB (Peak: 0.6790 MB) Data Comp: Off Server Time: 2026-06-24 10:19:56 UTC
