How big of a lift needed for 35" tires on a 1989 yj #801769 04/01/07 05:12 AM
blbiker Offline OP
I want to get a lift kit but dont know how big is needed for 35" swampers. If anyone knows just leave me a comment.
thanks
Bryce Lane,
Website: jeepwrangler1989.blogspot.com
Re: How big of a lift needed for 35" tires on a 1989 yj [Re: blbiker] #801770 04/01/07 06:19 AM
tanggang Offline
On a YJ with no body lift, the minimum recommended lift is 5". This can be done with the traditional leaf springs or with a coil over conversion. Depending on the weight of your rig you may wish to go with a taller lift kit or with a body lift. Keep in mind your ring and pinion and or power plant may also need to be upgraded to keep those big wheels turning.
Re: How big of a lift needed for 35" tires on a 1989 yj [Re: tanggang] #801771 04/01/07 07:05 PM
blbiker Offline OP
instead of a 5" lift could i get a 4" and then a 1" body lift.
would that still allow the placement of the tires on my vehicle?
Bryce Lane,
Re: How big of a lift needed for 35" tires on a 1989 yj [Re: blbiker] #801772 04/02/07 04:37 AM
G
Greg2000 Offline
a 4 inch lift with body trimming works great.
Re: How big of a lift needed for 35" tires on a 1989 yj [Re: Greg2000] #801773 04/02/07 05:25 PM
Brown81CJ5 Offline
I would recommend fender trimming with a little less lift. It will help keep your center of gravity lower. Then again not everyone is willing to cut up their body.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: How big of a lift needed for 35" tires on a 1989 yj [Re: Brown81CJ5] #801774 04/02/07 07:36 PM
blbiker Offline OP
would a 4" lift with the bushwacker fenders and trimmed body fit the 35" tires?
Bryce Lane,
Re: How big of a lift needed for 35" tires on a 1989 yj [Re: blbiker] #801775 04/03/07 07:53 AM
BobRowe Offline
If you're talking about the Bushwacker cut-out flares, then the answer is probably yes. You could go ahead and do the 4" suspension lift, cut the fenderwells and install the Bushwacker cutout flares, and see if you have enough clearance. The front tires will be the most problematic. Make sure you get it to full compression with the wheels turned each way.
If that's enough, then fine. If it's not, you can always install a 1" body lift later.
Another option is to go with a 3" suspension lift and a 2-inch body lift. The taller body lift means you have to watch more things during installation, but it also means a somewhat lower of center of gravity, and less likelihood of driveline vibration with a 3" suspension lift rather than a 4" lift.
Re: How big of a lift needed for 35" tires on a 1989 yj [Re: BobRowe] #801776 04/09/07 01:38 AM
blbiker Offline OP
hey thanks for all the help guys this is going to really help me decide how to setup all the lifts and accessories.
thanks.
Bryce Lane,
Re: How big of a lift needed for 35" tires on a 1989 yj [Re: BobRowe] #801777 04/09/07 11:41 AM
9
93yj Offline
I've posted this before, but just to change my body mounts (I went to Prothanes) was a NIGHTMARE.
There are threaded metal blocks INSIDE of the body that are otherwise inaccessable if the body mount bolt breaks or is too dang rusted to get out. I ended up having to cut into the body to get 4 of them out and just used grade 8 hardware to replace the blocks.
A job I wouldn't wish on my worst enemy!!!
Re: How big of a lift needed for 35" tires on a 1989 yj [Re: 93yj] #801778 04/23/07 04:31 AM
blbiker Offline OP
hey if i installed a 4" lift kit with half inch lift shackles that would be 4.5 inches of lift; would this allow the fitment of 34" tires or do i still need 5 inches of lift?
Bryce Lane,
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6348 MB (Peak: 0.7378 MB) Data Comp: Off Server Time: 2026-10-24 13:10:32 UTC
