5.0 swap #801793 04/01/07 08:59 AM
jonny_fookou Offline OP
i was goin to put the 3.4 in my 92 runner but i have come across a 93 thunderbird with the 5.0 for $400 im still not that great on searhing on here so any advice and links would be awsome <img src="/forums/images/graemlins/cheers.gif" alt="" />
--jonathan
Re: 5.0 swap [Re: jonny_fookou] #801794 04/01/07 01:36 PM
Rauch_Off_Road Offline
You won't really find much here for what you want. There may be other sites with more info out there but your best bet is to google it. You'll be looking at a rather significant overall cost, just remimber the engine needs to be mounted and be hooked up to the drivetrain somehow. Good luck.
(aka suprathepeg, aka Sean)
Re: 5.0 swap [Re: jonny_fookou] #801795 04/01/07 03:57 PM
eightyeight Offline
i know it's been done before, although not as common as a chevy v8 swap. if you get the whole car it would be really helpful.
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
Re: 5.0 swap [Re: jonny_fookou] #801796 04/01/07 04:36 PM
O
OutlawMike Offline
A few places to look for parts/adapters:
web page
Northwest Offroad sells engine mount adapters, custom oil pans, headers, etc for swapping a 5.0 into a Runner.
Also, Downey Offroad offers some info on swapping Chevy V-8's, but not much on the 5.0 Ford.
Biggest advantage to the 5.0, front distributor, not as much firewall massaging with a 3 lb sledge to clear the rear mounted distributor on the Chevy motors.
As stated above, if you are going to attempt this swap, get the whole donor car and keep it at your house / shop until you are sure you have everything swapped correctly and all of the bugs worked out.
Re: 5.0 swap [Re: OutlawMike] #801797 04/01/07 04:49 PM
i do have any thing on the car that contributes to it running i have the whole car
--jonathan
Re: 5.0 swap [Re: jonny_fookou] #801798 04/01/07 05:03 PM
thanks for the help so far but is it possible to reuse my automatic tranny for a while
--jonathan
Re: 5.0 swap [Re: jonny_fookou] #801799 04/01/07 07:02 PM
matts Offline
Advance Adapters makes a transfer case adapter that would let you use a Ford automatic. Not sure which automatics they work with or which one you've got in your T-bird. Take a look and let us know what you learn. -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6163 MB (Peak: 0.6900 MB) Data Comp: Off Server Time: 2026-10-21 18:53:16 UTC
