LSD for montero?? #801907 04/02/07 12:04 AM
A
Altuve Offline OP
Hi guys, where can I get a LSD or a lockers for the front and rear of my montero?? Only ARB?? thanks.
Montero 98, 5sp manual, Leaf Sprung, SWB, 3.0 V6 engine 12valve, 32" Kumho MT, custom bull bar, custom snorkel, 3 inch lift, KC highlight, 4.625 gears, 1.925 Low, part time 4WD non super select or active trac.
Re: LSD for montero?? [Re: Altuve] #801908 04/02/07 12:08 AM
LRJ4x4 Offline
Might help if you post what year and model truck you have <img src="/forums/images/graemlins/wink.gif" alt="" />
Depending on year, there is a factory locker, a factory LSD and ARB.
<img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: LSD for montero?? [Re: LRJ4x4] #801909 04/02/07 05:08 AM
A
Altuve Offline OP
Well, I own a rare montero, Its a 98, SWB, 3.0 V6 12 valve engine, leaf spung, 4.625 diff ratio, 1.925 Low range, It uses a 9" rear end Low pinion, and a 8" front High pinion. Thanks for your help.
Re: LSD for montero?? [Re: Altuve] #801910 04/02/07 05:28 AM
CapnCrunch Offline
Send an email to:
arbusainfo@arb.com.au
According to www.arbusa.com, to locate South American ARB dealers you need to email that address.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: LSD for montero?? [Re: Altuve] #801911 04/02/07 05:45 AM
LRJ4x4 Offline
Cool truck! BTW how much is gas there?
Re: LSD for montero?? [Re: LRJ4x4] #801912 04/02/07 05:59 AM
52degrees Offline
Too much to justify the trip just to fill up once. <img src="/forums/images/graemlins/lol.gif" alt="" />
KG6VNX
Re: LSD for montero?? [Re: 52degrees] #801913 04/03/07 04:32 AM
A
Altuve Offline OP
Good question...... well is extremely cheap, I fill up my Monty 60 liters with less than 2 dollars, and I put premium 95 octane....
Re: LSD for montero?? [Re: Altuve] #801914 04/03/07 01:30 PM
CapnCrunch Offline
Holy (#@&!!! That's around 12-13 cents a gallon!!!
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.008s) Memory: 0.6234 MB (Peak: 0.7016 MB) Data Comp: Off Server Time: 2026-11-02 14:18:15 UTC
