1989 SR5 4x4 no ignition power, no start, good battery #801997 04/02/07 05:57 AM
Davettman Offline OP
Hi, I have a 89 SR5 4x4 that was working fine til the battery went dead and it sat for a while. Put a new battery in and now no power when the ignition switch is turned on. The headlights and other things work but nothing off the switch. Git another ignition switch but still nothing. Anybody know if there is a fuse or something in between? When I jump the wire off the ignition wire harness the ignition comes on.
Re: 1989 SR5 4x4 no ignition power, no start, good battery [Re: Davettman] #801998 04/02/07 07:25 AM
Scerb Offline
The fuse for that is in the driver's side kickpanel - to the left of the pedals. Definently sounds like it could be your problem.
-Scerb
Re: 1989 SR5 4x4 no ignition power, no start, good battery [Re: Davettman] #801999 04/02/07 12:27 PM
ACES_HI Offline
X2........Sounds like a fuse. Had the same thing just happen. Test the fuses with a continuity tester. Even if they look good always doesnt mean they are.
'04 Taco x-cab 3RZ FE stock (daily driver)
'90 x-cab 22RE stock
'82 Hilux 6" lift (ACES HI)
'82 2-Hiluxs' Rally Edition (parts)
'81 Hilux 3" lift (parts/restore)
Re: 1989 SR5 4x4 no ignition power, no start, good battery [Re: ACES_HI] #802000 04/02/07 04:53 PM
MnMsToY Offline
not same year(1980) but same problem. I had to replace my ignition switch and a relay on the driver side kick panel.
my problem happened when I left the positive cable off the starter that I had to change out. My only way to get to the parts store was to pop the clutch with the starter out to get it replaced. I forgot all about the cable....well, on my way home it grounded out and blew the ignition switch and a relay. simple mistake that cost me a weekend of no wheeling trying to figure out what the problem was. I took out my whole dash apart. I had wires all over the place. Two days of fustration...just to have a friend come over pinpoint my problem in a few minutes. The relay looked fine on the outside...but I popped it open to see that it was fried up inside.
post up when you fix the problem.
Mike
1980 Toy, Dovetail, Chevy 60/14, 5.13 gears "Wheeling isn't cheap anymore"
http://www.texas4x4.org/gallery/MikesToyota
Re: 1989 SR5 4x4 no ignition power, no start, good battery [Re: MnMsToY] #802001 04/02/07 05:44 PM
Thanks...Alll good info. I'll check it today!
Re: 1989 SR5 4x4 no ignition power, no start, good battery [Re: Davettman] #802002 04/05/07 01:32 AM
O
oltrout Offline
had a similar problem with my 91 and mine turned out to be the circuit opening relay located behind the passenger side kick panel, you can check it by jumping it on the diagnostic port under the hood.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6095 MB (Peak: 0.6789 MB) Data Comp: Off Server Time: 2026-06-10 06:32:24 UTC
