coolant hose #802021 04/02/07 01:48 PM
'ol trigger Offline OP
Changed the oil over the weekend and noticed the "u" shaped hose located on the t-stat housing just underneath the upper radiator hose seemed pretty spongy feeling. I assume this is a coolant by-pass hose. When I replace the hose do I need to drain any coolant first? Does the hose normally hold coolant or is is dry when the engine is off?
Thanks,
Jim
Tulsa
'89 two door v6 auto
Re: coolant hose [Re: 'ol trigger] #802022 04/02/07 01:51 PM
G
generation_one Offline
Probably need to let out a gallon or more.
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
Re: coolant hose [Re: generation_one] #802023 04/02/07 05:26 PM
8
89IsMine Offline
Yup. Drain your coolant, otherwise when you pop the hose off you'll end up draining it anyways... <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Eric W.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5935 MB (Peak: 0.6465 MB) Data Comp: Off Server Time: 2026-06-20 18:15:45 UTC
