99 Montero quick clicking no start ??? #802106 04/02/07 09:42 PM
dick0309 Offline OP
dear all :
I really need your valuable comment for my Monty. couple question and here is the story.
my battery always mesure high voltage more than 16V. So,I think the voltage regulator of Alternator is gone. already have a new alternator to replace the old one. this is not causing me the problem yet. the current problem is "I can not start my truck". <img src="/forums/images/graemlins/angry.gif" alt="" /> <img src="/forums/images/graemlins/angry.gif" alt="" /> when you turn the key over, just have quick clicking sound no start. if you try couple times, then the battery voltage will drop to 9V. then if I disconnect the battery(-) cable, and reconnect it again. the voltage will go back to 12.6V. I also jump from my Nissan Altima, same thing clicking no start. this happen after I did not close all the doors properly and interior lights cause my battery out of power. I recharge the battery and re connect the battery cables. and turn the key to "on" position for couple hours for dinner. so, when I come back to start the car and just clicking sound and no start.
I search in this forum, and find the following possibile reasons.
1. bad battery cable.
2. bad starter or solenoid.
3. alarm (seems not the problem, I unplug 20A fuse and turn the key to "on" and put the fuse back, still the same.
4. bad battery (seems not the problem, because I jump from my Nissan Altima, and still the same.)
By the way, I just replace spark plugs couple days ago. after replace them, I ty to start my car several time, and it works fine.
can any of you give me a direction ? I will try to verify if the start or solenoid is bad.
thanks in advance.
Dick
Stamford, CT.
Re: 99 Montero quick clicking no start ??? [Re: dick0309] #802107 04/02/07 09:53 PM
Alex Kogan Offline
bad battery <img src="/forums/images/graemlins/smile.gif" alt="" />
08 PowerWagon (stock!)
Re: 99 Montero quick clicking no start ??? [Re: Alex Kogan] #802108 04/02/07 10:04 PM
dick0309 Offline OP
thank you for your quick respond. But, I also jump from my Nissan Altima and still the same problem. clicking no start. that's is why I think the battery is not the main issue. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: 99 Montero quick clicking no start ??? [Re: dick0309] #802109 04/02/07 10:14 PM
Alex Kogan Offline
If battery is truly dead it will take all the juice from Altima and starter will still make click, click.... <img src="/forums/images/graemlins/smile.gif" alt="" />
Swap a battery from you Altima for true test. Otherwise it might be a bad ground or + on stater solenoid.
Re: 99 Montero quick clicking no start ??? [Re: Alex Kogan] #802110 04/02/07 10:27 PM
sparkem Offline
Clean the battery posts and cables first, before you replace them.
Re: 99 Montero quick clicking no start ??? [Re: sparkem] #802111 04/02/07 10:51 PM
87Montero Offline
Yep, there is a $4 tool at Advance and Walmart to do this, or a wirebrush works fine.. I second the notion that the battery could be completly shot, or your jumper cables could be bad also. I had a pair that would work, but not 1--%, I had to get another pair to be able to jump my monty that was completly dead once.
Brendan
Re: 99 Montero quick clicking no start ??? [Re: dick0309] #802112 04/02/07 11:20 PM
LRJ4x4 Offline
How old is the battery?
Re: 99 Montero quick clicking no start ??? [Re: LRJ4x4] #802113 04/03/07 12:46 AM
dick0309 Offline OP
guys, you are the best !!! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
I exchange to the battery of Altima, and it start right the way. however I check the voltage of the battery, it is over 17V. I am afraid my alternator burn this battery too. <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" />
another stuip question, where is the check window of A/C freon level ? I found the freon receiver just in front of radiator. with a cap mark "H" and there is no window glass at all.
anyway, really appreciate your help.
Dick
Re: 99 Montero quick clicking no start ??? [Re: dick0309] #802114 04/03/07 04:06 AM
Alex Kogan Offline
What do you use to check voltage. If it's one of those cheap digital multi-meters beware they are ofter not good at all. I've one it always showed something like 16v. Used good ol analog - about 14v a lot better. It also showed my AA batteries with 1.8-1.9v as well. <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: 99 Montero quick clicking no start ??? [Re: Alex Kogan] #802115 04/03/07 12:40 PM
toddstidham1 Offline
My Gen I volt gauge on the dash always shows between 15v-16v, but when I test at the battery i show 14.6 using a good dvom and the same using my dads old old old analog volt meter. Always best to check at the battery. <img src="/forums/images/graemlins/kewl.gif" alt="" />
-Todd
1987 Montero 2.6l 5-speed (Sold...but I still miss her)
2008 Jeep Patriot Sport 4x4
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6414 MB (Peak: 0.7669 MB) Data Comp: Off Server Time: 2026-11-16 08:55:50 UTC
