Re: 99 Montero quick clicking no start ???
[Re: toddstidham1]
#802116
04/03/07 04:19 PM
I use a cheap digital multimeter. the reason why I test the battery is the dash meter show all the way up to the end. i think it is over 16V, and then I use the multimeter to mesure that it is over 17V and some thime it reach 19V I am not sure if my multimeter is correct or not. but, when I use the same multimeter to test the battery in my Altima, show 12.6v (not running) and 14V while you start the engine.
the is the reason why I thought my alternator voltage regulator is gone. But, now Ithink I need to verify this again. thank you all.
[Re: dick0309]
#802117
04/03/07 04:45 PM
well since it shows normal figures on Altima I would indeed suspect regulator.
92 SR, 285/75R16 Yoko MT ARB locker GAST compressor AirLift 1000 MM10500 Snorkel custom rear bumper 02 Montero LS died protecting the master 08 PowerWagon (stock!)
PHP: 7.4.33 Page Time: 0.018s Queries: 16 (0.014s) Memory: 0.5946 MB (Peak: 0.6593 MB) Data Comp: Off Server Time: 2026-11-18 22:36:07 UTCValid HTML 5 and Valid CSS
