33x10.50s?? #802118 04/02/07 10:04 PM
P
PETE_YK Offline OP
I've seen lots of write-ups on fitting 33x12.50s with minimal lift but none on fitting 10.50s. Im thinking about running 33x10.50s with 1.5in wheel spacers and then doing rims later. Would a 1 in body lift and trimming the fender seam be sufficient to clear them? Anybody out there run this size tire with minimal lift i'd like your input. Thanks.
88' Xtra cab, 22RE, 5 spd, alumi flat deck, 3" BL, 35" muds...awaiting SAS.
'02 Ram, 4.7, REV 'Shooter' wheels wrapped with M.T. Baja claws.
Re: 33x10.50s?? [Re: PETE_YK] #802119 04/02/07 10:21 PM
A
allochris Offline
to my opinion fitting a narrower tire is easier than a wider tire. so if 12.5" fits, 10.5" sure fits as well.
on my truck, no body lift but using 1.5"bJS & 15X8X3.75"BS RIMS, 32X11.5 & 33X9.5 fits no problem.
sorry to hijack your thread, but my friend wants to know if he can run 32x11.5 on stock rims 15x7x4.75bs on his stock 93 4runner with no fender tubbing.
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: 33x10.50s?? [Re: allochris] #802120 04/02/07 10:34 PM
eightyeight Offline
yes and yes. slight rubbing in both cases at full lock.
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
Re: 33x10.50s?? [Re: eightyeight] #802121 04/02/07 10:38 PM
A
allochris Offline
does the rubbing occurs at the swaybar 90? outside corner only ? where else? He also has stock running boards.
Re: 33x10.50s?? [Re: allochris] #802122 04/03/07 02:46 AM
drewdaddy Offline
Just put 32x11.50's on my 88, no rubbing at all!! Thank God! Everything stock..
88 P/U EFI 4x4... Stock for now.. 05 Corvette MN6 Z51 Package
Re: 33x10.50s?? [Re: allochris] #802123 04/03/07 03:40 AM
eightyeight Offline
well, i had 32x11.5's on my stock '87 runner and i actually had no rubbing at all, but it was really close to the pinch weld on the back of the front fender well. may rub the valence too.
-matt
Re: 33x10.50s?? [Re: eightyeight] #802124 04/03/07 03:51 AM
87Toy4x4 Offline
my buddy has 32x11.50's on his 94 4runner and he hasn't complained of any rubbing.
Re: 33x10.50s?? [Re: 87Toy4x4] #802125 04/03/07 05:51 AM
P
PETE_YK Offline OP
Just curious, will 32x11.50's fit on the stock 15x6's or are they too wide?
Re: 33x10.50s?? [Re: PETE_YK] #802126 04/03/07 03:29 PM
4Crawler Offline
They will probably fit OK, you may have trouble with increased center tread wear. I run 33x10.50s on 15x6s and even there it is hard to get really even tread wear. I usually settle for a little more center wear on the road and then off-road use chews up the side lugs, so evens out for the most part.
Re: 33x10.50s?? [Re: PETE_YK] #802127 04/03/07 04:25 PM
ZUK Offline
I liked the 33x10.50 all terrains that I had on my 87 Runner with 22RE/auto/571 gears. Lift was simple and cheap....cranked the front bars 1.5" and 3 inch "add-a-coils" in the rear. The 33" tires were on the factory 7" aluminum rims and had no rubbing from lock to lock. Even on trail rides with full compressions there was no tire contacts. I think the 10.50's will clear even with no lift of any sort.
I didn't have to do any other tricks to make them clear. The 10.50's are a nice riding tire....I didn't have the extra weight of the 12.50 tires so acceleration was good....the 571 gears helped also. ZUK
mostly stock
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6320 MB (Peak: 0.7389 MB) Data Comp: Off Server Time: 2026-05-27 20:57:44 UTC
