help needed...charge & brake light came on this morning #802381 04/03/07 03:40 PM
James Chow Offline OP
While driving to work this morning, after about 1 mile, the charge and brake warning lights came on. I pulled off, engaged/disengaged the e-brake to make sure it wasn't the e-brake switch (no difference), then drove home and swapped cars. When I got home, I parked, shut off the engine, then restarted it. It restarted fine (Optima red top is 2.5 yrs old), with the same two dash lights on. Anyone have this problem? I'm thinking the alternator probably bit the dust?
Someone remind me how to download the codes. I short out the plug in the left side engine compartment, turn the key to "on." Do I need to have the tranny in neutral and/or clutch down?
Sorry guys, I haven't been monitoring this board for a long time, at least not since I bought a 100 series as my new used vehicle and modded that. smile The 4runner has been delegated to DD work, currently at 200K mi.
'86 4Runner: ARB winchbar, Kaymar, e-codes, OME lift, RR diff lock, FR truetrac, sound stream a/d/s audio, recaros.
'03 LX470: ARB sahara bar, Kaymar, HID's, ART cryo'd/slotted rotors, Stoptech SS hoses.
'01 Prelude SH
'00 CRV
Re: help needed...charge & brake light came on this morning [Re: James Chow] #802382 04/03/07 03:42 PM
4Crawler Offline
Re: help needed...charge & brake light came on this morning [Re: James Chow] #802383 04/03/07 04:00 PM
grandeyota Offline
Did the belt break?
Reason I asked, I'm kinda used to getting bad alts from the parts store and didn't even think to look at the belt when it finally did break.
Fur clog in the sausage grinder
Re: help needed...charge & brake light came on this morning [Re: grandeyota] #802384 04/03/07 04:56 PM
Did the belt break?
Didn't have time to check, but I doubt it, as I just changed the belts w/ OEM ones 3 months ago.
'01 Prelude SH
'00 CRV
Re: help needed...charge & brake light came on this morning [Re: James Chow] #802385 04/04/07 01:36 AM
kewlynx Offline
Also make sure your brake fluid isn't low; switch in the cap. Thing sets off both lights.
If the belt broke, his temp would've pegged from the water pump stopping. <img src="/forums/images/graemlins/scared.gif" alt="" />
**ubi apis- ibi salus**
Re: help needed...charge & brake light came on this morning [Re: kewlynx] #802386 04/05/07 02:21 AM
canuck Offline
I'd take a hard look at the alt. I had the exact same thing and it was the alt. but check your belt and fuses first.
Keep the Shiney Side up. Support our troops.
Re: help needed...charge & brake light came on this morning [Re: canuck] #802387 04/08/07 02:16 AM
Smoke Offline
Sure sign of alternator fixing to or done gone!!
94 P/U Ex-Cab 3.0 Automatic 4X4
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6233 MB (Peak: 0.7135 MB) Data Comp: Off Server Time: 2026-05-26 04:57:32 UTC
