What is the biggest size of tire I could put on a factory Jeep setup? #802393 04/03/07 04:40 PM
kyrie_eleison Offline OP
I'm looking to buy bigger tires for my jeep but I don't want to put a lift kit in since I'm not sure how long I'm going to keep mine. It's a '04 Wrangler (6 cyl-4l). Anyone have any advice?
Re: What is the biggest size of tire I could put on a factory Jeep setup? [Re: kyrie_eleison] #802394 04/03/07 04:55 PM
cjensen Offline
Personally I would stay under the 29 1/2 - 30" mark. It seems from the posting which has been on here and many other sites that any thing over the 30" mark will wear and rub. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
jmho
C.
Re: What is the biggest size of tire I could put on a factory Jeep setup? [Re: cjensen] #802395 04/03/07 05:06 PM
thank you. I truly appreciate your opinion.
Re: What is the biggest size of tire I could put on a factory Jeep setup? [Re: kyrie_eleison] #802396 04/04/07 06:38 PM
Seattlegti Offline
I ran 30x9.5x15's on my XJ just fine before the lift.
They would rub a little at full turn when I was turning around on steep hills but not enough to do any damage.
The offset on the rims your using will make a difference.
The tires I ran on stock rims were fine but I tried a set of 30" Mud terrains on steel rims and they hit the fender well before full turn.
Re: What is the biggest size of tire I could put on a factory Jeep setup? [Re: kyrie_eleison] #802397 04/04/07 07:59 PM
A
Alloush Offline
I have 30's on mine. No rubbing no problems. I heard you can put 31's on TJ's without a lift. They shouldn't rub if you dont go crazy on the trail.
05 TJ 2.25 BB. Skyjacker hydro 7000 shocks.
Re: What is the biggest size of tire I could put on a factory Jeep setup? [Re: Alloush] #802398 04/07/07 08:37 PM
Macdaddy4738 Offline
I have a 98 TJ rockin 31's stock (as far as I know)
It doesnt rub one bit, and looks like I can fit 32's under there with no problems.
I wish I knew if It had a lift though..
Re: What is the biggest size of tire I could put on a factory Jeep setup? [Re: Macdaddy4738] #802399 04/07/07 08:56 PM
Brown81CJ5 Offline
you also have to keep in mind the actual tire size. My 31-10.50's are actually only 30 inches tall. Tires vary in height compared to what they are advertised as.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6112 MB (Peak: 0.6882 MB) Data Comp: Off Server Time: 2026-06-07 11:31:38 UTC
