Whaaat??? why is there black oil coming from.... #802671 04/05/07 02:10 AM
TrooperBeliever Offline OP
...my gas tank! I have an 86 Troop. In the center (on the bottom) of the gas tank there is a dran plug. When I park there acummulates a small puddle of pitch black oil(or oily substance) under the dran plug, that smells of gas. And I mean pitch black, it stained my finger even after 2 washings. So I'm really confused. It is definitly under the drain plug, NOT the diff. On the drain plug itself was a clear (no hint of color) liquid that smelled also of gas.
What could this be?
HELP!
Oh and thanks
(Formerly known as Black-n-Blue)
86 Troop --- for Hiking, Mtn.Biking, Camping, Canoeing, and Wheeling too!
"...and remember, If women can't find you handsome,
they should at least find you handy!"
-Red Green
Re: Whaaat??? why is there black oil coming from.... [Re: TrooperBeliever] #802672 04/05/07 02:58 AM
CPOM Offline
dirt and gas
CHRIS
98 Amigo, 92 Pup
Re: Whaaat??? why is there black oil coming from.... [Re: TrooperBeliever] #802673 04/05/07 03:48 AM
mlclark Offline
Isuzu Moderator
It's also probably dissolving any undercoating, plus the dirt, plus the grime.
Michael
Re: Whaaat??? why is there black oil coming from.... [Re: mlclark] #802674 04/05/07 05:51 AM
So Is this a leaky gas tank?
Is that plug for draining the gas?
then do I just need to tighten it up a bit?
or is there some sort of washer called for?
thx
-Red Green
Re: Whaaat??? why is there black oil coming from.... [Re: TrooperBeliever] #802675 04/05/07 06:21 AM
mlclark Offline
Isuzu Moderator
Well...you are probably going to have to crawl under there and take a look. I can't quite see it from here.
There is a copper washer under the plug. Easy fix if that is the problem.
Good Luck,
Michael
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6048 MB (Peak: 0.6688 MB) Data Comp: Off Server Time: 2026-07-14 01:55:36 UTC
