Engine blown...? #802837 04/05/07 05:13 PM
MaviSky Offline OP
A friends 1974 J10, 360, 4bbl stopped on him as he was driving around 35 mph. A big cloud of black smoke came out the tail pipe. the oil was very low when he checked. No metal or mechanical noises were heard when this happened. The engine turns over, but does not start. Any ideas on what happened??????
Re: Engine blown...? [Re: MaviSky] #802838 04/05/07 06:08 PM
RalkClimber Offline
Possibly sheared the Distributor gear... Take the distributor cap off and turn it over.. if the rotor button is turning then that's not it.. But if it isn't <img src="/forums/images/graemlins/frown.gif" alt="" />
Ralk
'97 Jeep Wrangler 2.5L 105k Miles
Recent Replacements: Cam Shaft, Lifters, Push Rods, Distributor, Dist. Cap/button, Plugs, Oil Pump, Oil Sending Unit, Timing Chain/sprokets, and all associated gaskets.
Re: Engine blown...? [Re: MaviSky] #802839 04/05/07 06:34 PM
BigJim Offline
Big cloud of smoke? If blue or white it means oil is burning.. If BLACK as you say it is excess gasoline. Might be the carb float or carb needle and seat has went away causing extreme flooding of the engine. So much so that it cannot digest the gasoline in liquid form.
TaKE THE AIR CLEANER OFF HOLD THE THROTTLE WIDE OPEN AND CRANK IT.. damn caps key.. carefylly looking into the carb for liquid while cranking.. also looking for liquid on the manifold.. Please don't be stupid and hold your face over the carb as a possible backfire will cause injury!!!
Re: Engine blown...? [Re: RalkClimber] #802840 04/05/07 08:27 PM
MaviSky Offline OP
Thanks for that idea. I'll check into that.
Re: Engine blown...? [Re: BigJim] #802841 04/05/07 08:29 PM
MaviSky Offline OP
BigJim,
Thanks for pointing me in that direction. I'll look at that and try not to shinge my hair.
Re: Engine blown...? [Re: MaviSky] #802842 04/05/07 11:06 PM
DBL_DTY97TJ Offline
It'll be more than a singe....Take it from a "stupid".
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: Engine blown...? [Re: DBL_DTY97TJ] #802843 04/05/07 11:27 PM
BigJim Offline
Hey DBL I've been told that a guy only does that once... Is that true?
Re: Engine blown...? [Re: BigJim] #802844 04/06/07 02:03 PM
DBL_DTY97TJ Offline
Yup. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Engine blown...? [Re: DBL_DTY97TJ] #802845 04/06/07 07:58 PM
RalkClimber Offline
Sadly... I've been there only once myself... heheh <img src="/forums/images/graemlins/notooth.gif" alt="" />
Ralk
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6260 MB (Peak: 0.7117 MB) Data Comp: Off Server Time: 2026-11-15 19:26:02 UTC
