Re: body lift [Re: IceBlueT] #802903 04/05/07 09:52 PM
RatLabGuy Offline
Funny this comes up, I'm doing my own 1" BL tomorrow.
I know you don't want to unbolt all the mounts at once, so the body dosn't slide around (that could get really bad fast!).
I've heard both to do it from rear to front (e.g., unbolt all but front, lift from behind, and work your way forward), then lift the front once rear is in place) and to do it side-to-side (e.g. do all one side, then teh other). Does it really matter?
And, are there any really good/bad jack points for that 4x4 block?
Question Reality.
Re: body lift [Re: RatLabGuy] #802904 04/05/07 10:06 PM
4Crawler Offline
See my directions (link above). Loosen 1 side, then remove nuts from opposite side, lift with a jack (lifting points in the above instructions) and install the lift blocks and longer bolts. Lower and loosely install the nuts then repeat the lift on the opposite side, finally lower and tighten all the fasteners.
Leaving the bolts in place with nuts in place provides a "hinge point" for the body to pivot on, but the bolts keep it from slipping sideways off the mounts.
Re: body lift [Re: 4Crawler] #802905 04/06/07 07:13 PM
Elbow_Greese Offline
I did the method 4crawler decribed for mine. No problems at all.
Mine was a cab-only lift, but not much more to do the full thing.
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: body lift [Re: RatLabGuy] #802906 04/06/07 08:25 PM
Myredyota Offline
Just read 4Crawler's directions. Once you get started, you will be just fine. My 4Crawler lift went on nice and easy! <img src="/forums/images/graemlins/cheers.gif" alt="" />
[color:"blue"]Carey[/color][b]
[b][color:"red"]89 SR5 Extended Cab 4X4 V6
[/color][color:"blue"]Don't forget to pay your taxes......
Millions of illegal aliens are depending on you!!![/color]
Re: body lift [Re: Myredyota] #802907 04/07/07 07:20 AM
IceBlueT Offline OP
ok. thanks for all the help! you guys are a great help.
and btw myredyota, we checked in class today.
21 million 300 thousand illegal immigrants is the latest estimate from the government. just thought you might like to update your signature...
formerly 277000_yota
Old enough to know better, but still to damn arrogant to care...
]www.cardomain.com/ride/2614269
'90 'Yota 4X4 (10/31/05-09/10/08 R.I.P)
'98 'Yota t-100. 3.4, 5 sp. 4x4, 2 in. Toytec with BFG A/T 265/70R16s
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6141 MB (Peak: 0.6955 MB) Data Comp: Off Server Time: 2026-06-07 04:13:07 UTC
