R151 into 1985 Carbed 4x4... #802908 04/05/07 07:35 PM
84toyota Offline OP
I'm looking at swapping a '86 turbo transmission/transfer case (r151) into my '85 22r (carb) 4x4 which has the G52 transmission... I'm pretty sure I have the answers to my questions, but want to double-check... will I have to modify the floor boards at all to fit the R151? The bell housing should match up? What about a clutch/flywheel combination? Do I need a bigger clutch/flywheel for the turbo transmission, or will the original ones work? Are there any other secrets to the G52 - R151 swap? Will the drive-shafts need modification? What about the mounting locations on the crossmember?
Sorry for all of the questions...
Thanks,
Ken
1984 Toyota 4x4 Truck, 4.88's, 32x11.50's, weber 32/36, aux gas tank, Warn 9500i, SR5 guages, tilt/altimeter, Alpine stereo with dual 12's behind the seats.
Re: R151 into 1985 Carbed 4x4... [Re: 84toyota] #802909 04/05/07 08:02 PM
Red_Chili Offline
Toyota Section Staffer
I don't know about the G52 specifically, but I would go in assuming you will have to modify the floorboard. Not hard to do. The bellhousing fits a 22R block, and normal 22R clutch, so no worries there. You may need to modify driveshafts but I tend to think not. I would be very uncertain about the crossmember; you should be able to modify the stocker though if you need to.
HTH!
-Bill
Re: R151 into 1985 Carbed 4x4... [Re: 84toyota] #802910 04/07/07 06:56 PM
matts Offline
I did this very swap into a my '84 xtra cab. It was pretty much a straight across swap. <IIRC>The G52 tranny that came with carbed trucks had the same shifter location as the R151F. If the truck had been equiped with a 22RE it would have a W56 tranny which, so I've been told, has the shifter farther back. The clutch from your 22R will work, but you could get a flywheel and clutch from a '93 - '95 22RE, which is the same as the slightly larger ones that came with the turbo 22RTE in '86 - '87. I paid $35 for a flywheel at the boneyard and about $50 to get it resurfaced. JT Outfitters sells a good stock type clutch. JT also has this clutch up as an eBay auction here. For a high performance clutch it looks like Marlin Crawler might be the best bet.
Oh yeah, the output flanges on the turbo setup have a larger bolt pattern than the ones that came with your truck. No problem though, your flanges will swap right over. Just remember to clean the splines on the T/C and the flanges with a solvent like brakeclean and seal them up with grey RTV, otherwise you'll have oil leaks at the flanges.-- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5939 MB (Peak: 0.6476 MB) Data Comp: Off Server Time: 2026-05-29 22:41:52 UTC
