remember that noise I thought was an injector..... #803022 04/06/07 12:54 AM
I
irsean Offline OP
It turns out it was a camshaft journal wearing down. I am going to replace my cam shaft(s). Is there anything want to know or anything special I want to do before I get started?
1993 4Runner SR-5 4WD V-6 Auto Trans
1990 Pick-up (Hilux) 2WD SR-5 V-6 Auto Trans
Re: remember that noise I thought was an injector..... [Re: irsean] #803023 04/06/07 02:59 AM
I
irsean Offline OP
I just pulled the head covers and found a "tweaked"
shim lying in the oil reservoir. Also the corresponding cam journal is worn down.
Re: remember that noise I thought was an injector..... [Re: irsean] #803024 04/06/07 02:59 AM
I
irsean Offline OP
The other cam looks good but, should I replace it as well?
Re: remember that noise I thought was an injector..... [Re: irsean] #803025 04/06/07 03:01 AM
I
irsean Offline OP
Now I just need a tool that will hold the cam sprockets while I get them loose.
Re: remember that noise I thought was an injector..... [Re: irsean] #803026 04/06/07 03:19 AM
kewlynx Offline
Sean, I don't know if you're aware, but there is a 93 FSM sticky'd at the top of this section for your guidance, esp in the inspection phase.
**ubi apis- ibi salus**
Re: remember that noise I thought was an injector..... [Re: kewlynx] #803027 04/06/07 03:46 AM
I
irsean Offline OP
I have poured over that thanks. Just wondering if there's anything else anyone can add. It's going pretty well. I think I will replace both cams since I have them exposed.
Re: remember that noise I thought was an injector..... [Re: irsean] #803028 04/06/07 04:03 AM
I
irsean Offline OP
I guess one question I would have is whether I should buy an OEM set or aftermarket and if so, what would be best for gas milage (product suggestions welcome at this point.)
Re: remember that noise I thought was an injector..... [Re: irsean] #803029 04/06/07 06:52 AM
Rauch_Off_Road Offline
Get one of the cams sets from sea2sky.com.
(aka suprathepeg, aka Sean)
Re: remember that noise I thought was an injector..... [Re: Rauch_Off_Road] #803030 04/06/07 07:24 AM
I
irsean Offline OP
that address doesn't work.
Re: remember that noise I thought was an injector..... [Re: irsean] #803031 04/06/07 07:37 AM
Snowtoy Offline
To break the cam gear bolt lose you need either an 1-1/8" or1-1/4" wrench, and a 2x4 about 18 inches long. For the passenger side cam gear place the 2x4 on end on top of the upper arm and brace the wrench against it, for the driver's side use the top of the engine, to install reverse the procedure. Be careful when breaking the cam gear lose, they are prone to breaking
PHP: 7.4.33 Page Time: 0.048s Queries: 16 (0.006s) Memory: 0.6384 MB (Peak: 0.7446 MB) Data Comp: Off Server Time: 2026-10-24 13:12:08 UTC
