Transmission Question. #803182 04/06/07 06:41 AM
Trail_Maker Offline OP
This may sound like a silly question but, I was wondering... How the Automatic tranny works with the motor. Does the automatic tranny detect the RPM's from the motor then decide to shift and down shift or does the Main computer to the motor tell the transmission to shift. Does the transmission monitor the fuel pedal position, for instance, when you floor it then it down shifts? May sound like a silly question to all you veterans, But I am not a veteran, thanks in advance.....!! <img src="/forums/images/graemlins/drunk.gif" alt="" />
1990 LWB 3.0L With 33/12.50's K&N 251k Miles
Re: Transmission Question. [Re: Trail_Maker] #803183 04/06/07 06:49 AM
LandRaider Offline
Re: Transmission Question. [Re: Trail_Maker] #803184 04/06/07 08:55 AM
52degrees Offline
Pretty much, the answer to all your questions is YES!
KG6VNX
Re: Transmission Question. [Re: 52degrees] #803185 04/06/07 11:52 AM
Y
yankneck696 Offline
On tiyr 90, tou have a transmission computer that gets signals from your ECU, A/C, power steering & others.
The ECU sends a digital signal to the trans computer & the trans gets controled from there.
Ed
Yankneck = Yankee ingenuity with Redneck stupidity.
"How can I break it better?"
89 Raider 3.0 w/ 31's for now
Re: Transmission Question. [Re: yankneck696] #803186 04/06/07 03:19 PM
Thats all I wanted to know, thanks! Guys! <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Transmission Question. [Re: yankneck696] #803187 04/06/07 07:19 PM
TommyM Offline
Some of the above info is not quite accurate.
The only electrically-controlled part of a Gen I auto trans is the overdrive solenoid. Otherwise, it's all done through hydraulics in the trans. There is a TV cable to signal the "throttle position" to the trans, but again, it's a hydraulic/mechanical thing, not electric.
Tommy
90 LWB Montero, 270k, 265/75R16, 16x8 ARE Bajas, Budget Lift, Towbar, Aux Brakes (towed with camper), Jotto Desk, remote oil filter
92 bone stock base model beater
Parting out 4 more
Re: Transmission Question. [Re: TommyM] #803188 04/07/07 12:17 AM
52degrees Offline
I didn't notice the GenI sig line <img src="/forums/images/graemlins/shiner.gif" alt="" />
KG6VNX
PHP: 7.4.33 Page Time: 0.018s Queries: 15 (0.014s) Memory: 0.6205 MB (Peak: 0.6947 MB) Data Comp: Off Server Time: 2026-11-17 11:30:48 UTC
