15W-40 #803234 04/06/07 03:48 PM
john_luttrell Offline OP
Guys I have come across an endless supply of AMSOIL 15W-40 fleet oil and I'm curious weather or not to use it in my 91 YJ. The specs say its good for diesel and gas engines; anyone have any experiance with it? My engine in my old YJ has a fresh rebuild with only about 8K miles on it.
John Luttrell
2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
Re: 15W-40 [Re: john_luttrell] #803235 04/06/07 03:56 PM
BigJim Offline
Howdy John 15-40 should be ok to use. The oil will be at 15 on cold winter mornings and at 40 in a running engine. I use the same oil in my deisels and if I come up short I use it in anything that needs some added.
Around here straight 40 weight would be ok all year. Specially in a worn older engine where the clearences are opened from wear.
Re: 15W-40 [Re: BigJim] #803236 04/06/07 04:10 PM
Thanks Bigjim, that's what I thought. What ya think about my daughters little '97 Saturn, will it be ok in it as well?
John Luttrell
Re: 15W-40 [Re: john_luttrell] #803237 04/06/07 04:28 PM
BigJim Offline
Why not? It's Ok for lawnmowers ain't it? <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 15W-40 [Re: BigJim] #803238 04/06/07 09:09 PM
9
93yj Offline
I know a couple guys that specifically use 15w40 and nothing else in their GAS engines...diesel oil has more detergents as well, so it'll keep you running clean!!!
Re: 15W-40 [Re: BigJim] #803239 04/06/07 09:42 PM
jstritec Offline
are you selling shares in Luttrel oil yet?
80 CJ-7.
It runs
Re: 15W-40 [Re: jstritec] #803240 04/08/07 01:46 AM
playinmud Offline
you can use that in any motor you would like. amsoil has the best lubricants out there i run their 0w-30 in my jeep and it doesnt burn any, it also starts right up like it does on a 75 degree day when its 0 degrees out, you can go a hole year without changing your oil and you see increased fuel economy. my brother has used it in his 87 grand national with 80,000 miles on it for a while and a couple months ago when he pulled the valve covers off to replace the valve springs it looked like it was a brand new engine i wish i had pictures because none of us could believe it
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
Re: 15W-40 [Re: playinmud] #803241 04/08/07 02:18 AM
BigJim Offline
I gotta doubt any increase in milage! I doubt the worst milage oil and the best milage oil would be findable by the driver.. Perhaps highly sophisticated machines could find a mile in a tank but real people???
Re: 15W-40 [Re: BigJim] #803242 04/08/07 03:26 AM
playinmud Offline
if you were to use lets say pensoil oil and then switched over to amsoil you would get better milage
Re: 15W-40 [Re: playinmud] #803243 04/08/07 04:48 AM
BigJim Offline
How would one be able to tell?
If that is really true, why?
PHP: 7.4.33 Page Time: 0.016s Queries: 16 (0.010s) Memory: 0.6332 MB (Peak: 0.7569 MB) Data Comp: Off Server Time: 2026-10-26 21:06:27 UTC
