A couple of EFI sensor questions, 3.0 v6 #803278 04/06/07 06:05 PM
Sinkut_Laker Offline OP
Hi everyone,
this is my first post on this forum since the t4X4 one died. It's nice to see so many of those regulars here.
I will have lots of questions this spring, as I plan (tentatively) to swap 3.0v6 engines in my truck (I have one in a wrecked 4runner that I ran yesterday, and it has 200K km less than my truck's engine).
Today, though, I'm just looking at getting things running in my truck a bit better. Looking back at some old posts on this site, I see one guy saying that his v6 was getting terrible gas mileage in colder weather, and normal gas mileage in warmer weather. This is my problem, too.
4Crawler suggested:
1/ check cold start injector time switch
2/ check ECU coolant temperature sender
Any advice on how to check these two items? I believe I can find them both, but how to check their performance and specs? I have multimeter and some know-how...
I also wonder if it's possible to test the O2 sensor, either on or off- vehicle. I have two of them on vehicles, but both could come off for testing.
Can anyone point me to procedure/specs? Is it even possible?
Thanks very much in advance,
Scotty.
1990 4X4 Pickup V6
390 000 KM
Tired engine, 4.10s, and 31" tires
Dog, Canoe, ATV
Re: A couple of EFI sensor questions, 3.0 v6 [Re: Sinkut_Laker] #803279 04/06/07 07:20 PM
dcg9381 Offline
sinkut,
First - invest in / get a copy of the FSM (Factory Service Manual) - this manual would answer your questions.
The ECU coolant temp sender needs to be checked against a defined range of resistance at a specific temp.
If you want a more accurate test, you pull it off, test it in ice water, at room temp, and in boiling water.
The 02 sensor is best tested while active/hot. It will "dither" or produce a specified range of voltages, back and forth X times per specific unit time...
Again, the FSM has the specifics.
22REturbo.net
1988 4Runner
Re: A couple of EFI sensor questions, 3.0 v6 [Re: dcg9381] #803280 04/07/07 06:24 AM
Rauch_Off_Road Offline
FYI there is a FSM stickied to the top of this forum.
(aka suprathepeg, aka Sean)
Re: A couple of EFI sensor questions, 3.0 v6 [Re: Rauch_Off_Road] #803281 04/07/07 06:59 AM
Thank you, I have the FSM now and just need to run it through Acrobat Pro on my other machine to put all those little pages together.
Scotty
1990 4X4 Pickup V6
390 000 KM
Dog, Canoe, ATV
Re: A couple of EFI sensor questions, 3.0 v6 [Re: dcg9381] #803282 04/07/07 06:59 AM
Thank you, I'll check it out and see how far I get!
1990 4X4 Pickup V6
390 000 KM
Dog, Canoe, ATV
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6052 MB (Peak: 0.6702 MB) Data Comp: Off Server Time: 2026-06-07 05:46:54 UTC
