no fire NEED HELP #803315 04/06/07 08:49 PM
mountinmuddin Offline OP
93 jeep wrangler getting no fire, replaced crank position sensor, coil pick up sensor still no fire? <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: no fire NEED HELP [Re: mountinmuddin] #803316 04/06/07 09:06 PM
9
93yj Offline
Did you replace the coil itself, or just the pickup in the distributor and the CPS?
Re: no fire NEED HELP [Re: 93yj] #803317 04/06/07 10:12 PM
already tried a new coil! can,t figure it out!
Re: no fire NEED HELP [Re: mountinmuddin] #803318 04/07/07 04:00 AM
9
93yj Offline
The distributor is plugged in at the harness, right?
Did you check the harness for voltage?
Did you try cranking her over without the distributor cap on to see if the rotor is spinning?
Re: no fire NEED HELP [Re: 93yj] #803319 04/07/07 05:57 PM
cjensen Offline
Is it auto or manual?
If manual could be the safety switch. Did you check all of your fuses and relays and such. Did you check and clean all your grounds and positive connections?
C. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: no fire NEED HELP [Re: cjensen] #803320 04/07/07 08:08 PM
BobRowe Offline
If the trouble is caused by either theclutch interlock switch on a manual tranny, or the neutral safety switch on an auto tranny, the engine shouldn't even crank over.
Re: no fire NEED HELP [Re: mountinmuddin] #803321 04/07/07 08:54 PM
8
82shortbox Offline
Just got my "new" jeep running after sitting for 4 years in a horse barn. My problem was the ignition module causing the starter to stick on and no spark. Also same thing on my 80 Dodge truck, would turn over but no spark , ended up being the ignition module also. Most auto parts can test them. Gordie
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6098 MB (Peak: 0.6862 MB) Data Comp: Off Server Time: 2026-06-22 06:15:24 UTC
