front side #803406 04/07/07 07:13 AM
superduperbacon Offline OP
hey i smashed up the front of my truck pretty good... anyway i was lookin for any advise on how to fix it. the accident pushed the radiator into the fan, so the fan cant move. deformed the front sheetmetle piece, and bent the mounts that connect the bumber to the frame via weld. the frame is still good though!
Re: front side [Re: superduperbacon] #803407 04/07/07 12:02 PM
rustylux Offline
Tie a rope around the bent radiator support and tie the other end around a tree. Reverse up with a bit of speed until it's semi straight again. Do the same with any other parts that are bent. Find replacement panels... mount em up and you're laughin.
I've done this with a couple of vehicles now and apart from a few strange stares from the neighbours it all went pretty well. Thats how I fixed this:
Re: front side [Re: superduperbacon] #803408 04/07/07 03:50 PM
cktoy Offline
My truck was smashed in when I bought it .Parked in front of a bigger truck ,chocked the wheels on both,used two cum a longs to pull out the rad grill support,replaced the radiator,grill,hood,latch,took the torch to the old bumper.used 2" pipe for the new bumper.used "great stuff foam to help hold the headlights in place then painted it black, it will never be perfect but its pretty good.I got familiar with the local pull a part <img src="/forums/images/graemlins/notooth.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" />
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: front side [Re: superduperbacon] #803409 04/07/07 09:42 PM
ok so i pulled the front sheet metel back to somewhat how it used to be... but anyway the radiator was done, the fan shroud got chewed up in the power steering pulley, and the fan got pinched up on the top end by the radiator and the fan shroud, so it couldent move unitll i pulled the radiator out. now the fan seems to be ok but when it was rotated the fan seemed to be a little wavey. its not perfectly straight, as far as i can tell the fan clutch is ok but do you think it would be a good idea to replace the fan or would it still work. my concern is having this wavey fan turning at a high speed might cause something bad to happen.
Re: front side [Re: superduperbacon] #803410 04/08/07 12:28 AM
E
eastcoast Offline
id replace it. in one of my brighter moments some years back, i replaced the alternator and forgot to tighten the bottom pivot bolt....alternator was cocked to one side and the lateral stress it put on the crank pulley caused it to shear off the pulley hub, costing me a new crank pulley, alternator and a 6 mile walk home at 2 am. even if the fan pulley itself isnt bent, pulleys arent meant to take stress in the wrong direction(anything but linear movement). ps bodywork sucks! good luck man
'94 X-Cab, EB inside and a few fabbed parts. My wife: "How about you stay on the road?" Me: "I drive a Toyota truck, the road is OPTIONAL!"
Re: front side [Re: superduperbacon] #803411 04/08/07 02:36 AM
rustylux Offline
I had the same problem on that Falcon I showed earlier. The fan got stuck under the rad support. It had a bent fin but I didn't replace it straight away. After I replaced everything else that was bent/busted, I drove her around for a couple of weeks. The wobble from the out of balance fan got worse and the twisted fin sheered off at high speed.
It demolished my new radiator and put an interesting dent in the hood. I also chewed out my water pump. That little episode taught me to do things the right way the first time... lol
Re: front side [Re: rustylux] #803412 04/09/07 03:11 AM
hey guys thanks for all the input, i'll be on my way to the pick n pull to get some new parts here pretty soon. she'll be back on the road by the end of the week.
Re: front side [Re: superduperbacon] #803413 04/09/07 03:14 AM
kewlynx Offline
The guys have you set up pretty well; take a moment and look at the pulley grooves on everything from the side of the truck; if they're not lined up, you might've slightly bent a bracket.
Give 'er a good lookin' over. <img src="/forums/images/graemlins/kewl.gif" alt="" />
This dude decided he needed to use a tree to stop; check out his field fix
BLAM n JAM
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6219 MB (Peak: 0.7171 MB) Data Comp: Off Server Time: 2026-06-21 01:26:22 UTC
