97 t100 4x4 Front spindle nut #803414 04/07/07 07:19 AM
97T100SR54X4 Offline OP
I purchased a 54mm hub socket (OTC 6612 part number).
How snug should you tork the nut on the front spindle and bearing?
Fix it myself
1997 T100 SR5 4X4 190,000 miles
Ext.Cab 5 speed standard All original
Except: Bilstein shocks,Steering stabilizer
Aisin Hubs
Re: 97 t100 4x4 Front spindle nut [Re: 97T100SR54X4] #803415 04/08/07 04:21 AM
ErikB Offline
Toyota Moderator
http://4x4wire.com/toyota/maintenance/front_end/reassembly/
I think one of my FSM's says 25ft/lbs for the inner, but I go tighter than that since my D44 manual says 50. Obviously its not real critical as long as they aren't too loose.
http://home.4x4wire.com/erik
Re: 97 t100 4x4 Front spindle nut [Re: ErikB] #803416 04/08/07 02:34 PM
Thank You ErikB. I bookmarked the link it is very helpful
Bryan <img src="/forums/images/graemlins/cheers.gif" alt="" />
Fix it myself
Aisin Hubs
Re: 97 t100 4x4 Front spindle nut [Re: 97T100SR54X4] #803417 04/08/07 02:46 PM
surlynkid Offline
you overtighten it, loosen it a little bit and then torque it down. that is for the inner one. then put that star washer in there and torque the outer one. then bend the tabs on the star washer. use the torque specs in the article.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.004s) Memory: 0.6003 MB (Peak: 0.6598 MB) Data Comp: Off Server Time: 2026-06-09 21:51:06 UTC
