I guess I will have to do it #803514 04/07/07 08:03 PM
G
generation_one Offline OP
I have a pin-hole leak in the top of my radiator near the upper hose. I put the steel wool to it and, now have it down to bare metal...and a tiny hole with hairline crack is visible.
So my choices are:
A..plumbers solder- low melting point, but not a strong material. Doesnt build up a cap very well either
B..braizing rod- high melting point might cause damage to radiator, but will easily cap off a hole this small
C..the newer stuff like staybrite 8 - supposed to be good stuff (when used for copper tubes to brass)
fairly low temp but durable
I wonder hot I can get this metal ?
What do repair shops use? Does anyone have a clue about these radiators?
It's marked Denso- I guess it is the original one
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
Re: I guess I will have to do it [Re: generation_one] #803515 04/07/07 11:04 PM
SpideyRaider Offline
Is the hole in the core or on the top? I had a little leak on top near the cap and used some high temp epoxy and haven't had any issues whatsoever. And the epoxy was only a couple of bucks!
'87 Raider - 2.6L Rebuilt by me, BSE installed.
Superwinch manual hubs. LSD, Squirters and bouncy seat added. Cobra CB w/ PA (PA coming soon). 31x10.5x15 Futura Dakota rubbers; Pro Comp Add-A-Leaf w/ Rancho RS500's in the rear, KYB's up front.
Re: I guess I will have to do it [Re: SpideyRaider] #803516 04/08/07 12:12 AM
LandRaider Offline
Solder it up with a propane torch, or mapp gas, and some silver solder.
Easy fix.
Re: I guess I will have to do it [Re: LandRaider] #803517 04/08/07 02:06 AM
Easy fix.
Thats what I would do. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: I guess I will have to do it [Re: cmonty72] #803518 04/09/07 02:10 AM
Radiators are put together with solder, and note that the upper tank is soldered to the core. I would still solder it, with silver solder, but I'd keep a wet rag between the solder site and the core-tank joint. Radiator shops use a very wide cool gas flame under quite low pressure for their soldering work, but I guess you'll need more heat for silver than lead....
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6065 MB (Peak: 0.6713 MB) Data Comp: Off Server Time: 2026-06-09 21:43:42 UTC
