I need help #803549 04/08/07 02:10 AM
spplater Offline OP
I have a 87 4runner, I just changed the timing chain, water pump, and oil pump. I got it all back together, set the timing and it will run at idle with no noises, as soon as i step on the throttle the engine dies. does anyone have any idea what might be wrong?
Re: I need help [Re: spplater] #803550 04/08/07 02:25 AM
O
ovrrdrive Offline
Sounds like you're a tooth off on the cam timing to me...
Re: I need help [Re: ovrrdrive] #803551 04/10/07 03:50 AM
Smoke Offline
Sure sounds like a timing problem to me!!
94 P/U Ex-Cab 3.0 Automatic 4X4
Re: I need help [Re: spplater] #803552 04/10/07 04:13 AM
kewlynx Offline
Hi, welcome to the board
Give this a read thru TChain R&R
and, from our Toyota tech archives,
Timing Chain tech
Yeah, sounds like you're off a scooch. Did you make sure the engine was at TDC before you pulled the distributor when you started? Often overlooked.
**ubi apis- ibi salus**
Re: I need help [Re: kewlynx] #803553 04/10/07 07:03 PM
DRTDEVL Offline
I don't think a tooth off would cause this. Why?
I advance my cam 1 tooth when towing heavy loads to lower the powerband... I get amazing torque off idle, right up to about 3,000 rpm. It falls on it's face after 3400 rpm, though.
If I retard the timing a tooth, I get no power off idle, but high rpm torque. I see no practical purpose for this setup, though, so I don't use it.
When spot on, I get decent torque from 2000-4000 rpm, and decent overall performance (EB 270/430 cam). It's a bit high on the powerband, but it suits me perfectly trying to run down the autobahn at 100+ mph.
I would be leaning more towards a torn intake boot. When he hits the gas, the tear opens, allowing enough unmetered air into the system to stall the truck.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6053 MB (Peak: 0.6692 MB) Data Comp: Off Server Time: 2026-05-29 16:09:07 UTC
