smog
#803607
04/08/07 08:50 AM
I have a 1989 4 runner that won't pass smog. Ive replaced the mass air flow sensor , the TPS ,cap & rotor,spark plugs PVC valve and a BOSCH universal O2 sensor. I have also run injector cleaner thru the gas tank & checked the EGR system and it is working. The smog check was - @ 2500 rpm the limit for the HC ppm 220 and the truck read 90 (pass) the CO% limit is 1.20 the truck read 1.16 (pass). The idle test @ 796 rpm is HC ppm limit is 220 the truck read 253 (fail) and the CO% limit 1.20 and the truck read 4.44 ! (fail)!!! . What could cause this ? should I bump the idle speed up to 1000rpm ? Would retarding the timing 2 deg help ? Any help is welcome . <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: smog
[Re: rollin]
#803608
04/08/07 11:20 PM
J Roll Me Over
Ditch the Bosch sensor... Get a Denso.
The Bosch sensor does not protrude enough into the exhaust stream to get an accurate reading, and will allow your engine to run rich.
Other than that, the Cat could need replacement. I am still leaning towards the Bosch sensor.
Re: smog
[Re: rollin]
#803609
04/09/07 06:22 AM
I had a faulty coolant temp sensor that caused bad readings at smog check.
Re: smog
[Re: SoCalRunner]
#803610
04/10/07 04:41 AM
Thank you , was there only one temp sensor ?
Re: smog
[Re: DRTDEVL]
#803611
04/10/07 04:42 AM
Thank you, I will try that.
Re: smog
[Re: rollin]
#803612
04/10/07 05:03 AM
Re: smog
[Re: kewlynx]
#803613
04/11/07 01:06 AM
Re: smog
[Re: rollin]
#803614
04/16/07 04:02 AM
whooohooo it passed the 02 sensor worked!!! Thank You all so much ! <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6197 MB (Peak: 0.6967 MB) Data Comp: Off Server Time: 2026-06-09 10:05:44 UTCValid HTML 5 and Valid CSS
