2004 trooper Differetial air lockers #803615 04/08/07 12:07 PM
G
Gabriel69 Offline OP
Hi
I am interested in front and rear diff lockers(Air Lockers) for my 2004 Isuzu trooper.(3.0 turbodiesel)
I understand that there is a setup for the front axle but there is a problem with the rear axle on the 2004 model?
Please correct me if I am wrong.
Is there a solution for the rear axle.
Any suggestion would be welcome.
Best Regards.
Gabriel.
<img src="/forums/images/graemlins/confused.gif" alt="" />
Bleeding once in a while is good,it always will remind us-HOW FRAGILE WE ARE.
Drive safely!
Re: 2004 trooper Differetial air lockers [Re: Gabriel69] #803616 04/08/07 01:57 PM
Smiley Offline
Greetings, and Welcome! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Based on a few conversations that I've had with several Trooper owners, here's what I can tell you...
The later 2nd Gens were equipped with a modified 12-Bolt rear axle, and you are correct that there are fitment problems when attempting to install an ARB Locker into one of them.
The solution would be to install an earlier non-modified 12-Bolt axle -- something out of a 1996-97 (perhaps up to 1999 - not sure) *should* work perfectly...
However, I say "should" because I am not sure if there are any gearing (or perhaps other) differences with the oil-burner models, since we do not have those here in the US.
I hope this helps <img src="/forums/images/graemlins/wink.gif" alt="" />
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: 2004 trooper Differetial air lockers [Re: Smiley] #803617 04/08/07 03:18 PM
G
Hi Smiley
Thanks for the prompt reply.
If I am not mistaken then there is a matter of size diffrence between the two axles.
As I recollect the Isuzu guys had made the wheelbase a bit wider in the 98,99 models and on.
The story here in Israel is that the ARB dudes got pissed of at the Isuzu guys for not notifying them in advance about the size change in the axle and they did not seem to care about planning a new one <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" />
Gabriel.
Drive safely!
Re: 2004 trooper Differetial air lockers [Re: Gabriel69] #803618 04/08/07 06:12 PM
Smiley Offline
I can only answer that as it applies to the Trooper we got here in the States...
AFAIK, if it has wide fenders, it has the wider axle - and *here*, the wide fender models started showing-up in late 1995 (IIRC).
Anyone wanna double-check me on this?
Also, Joe (BigPoppa) has reported in this thread's counterpart, at The Planet, that there *is* an ARB Locker for the modified 12-Bolt -- I was totally unaware of this.
Re: 2004 trooper Differetial air lockers [Re: Smiley] #803619 04/09/07 03:24 AM
matthew Offline
WRONG
we have set up several 1998 and later "mofified 12 bolt" rear diffs w/ the ARB airlocker.........NO ISSUE.
we used 1998-99 trooper rears w/ trak-lok LSD unit.
we can set one up and ship it to Isreal.
'93 RS 3.2L - DD/trail build
'97 7.3L Powerstroke - tow rig
'71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build
Owner: http://www.INDEPENDENT4x.com
m-f 9am-6pm EST. 804-550-0480
Re: 2004 trooper Differetial air lockers [Re: matthew] #803620 04/10/07 12:13 AM
G
WRONG
This is the best suggestion I've had in years.
Lets do this,I'll be the only guy in Israel with a rear ARB air locker on a trooper.
Please give me the details and we will proceed.
If this works I wiil hook you up with our forum members.
I am possitive that lots of other trooper owners will order from you.
Good luck to us all.
Gabbriel.
Drive safely!
Re: 2004 trooper Differetial air lockers [Re: Gabriel69] #803621 04/10/07 06:42 PM
lttlbddy Offline
www.independent4x.com
This is Matt's company. Contact him through there and keep us all posted!!
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6195 MB (Peak: 0.7121 MB) Data Comp: Off Server Time: 2026-06-09 21:34:25 UTC
