93 Spring Project #803625 04/08/07 12:27 PM
5
5150 Offline OP
Heres is the work done thus far. Plans include fiberglass bedsides, new fenders, shocks bumpers, tailgate and wheels. I want to replace the brakelines to the LSPV while the box is off. Anyone done this. Are the old lines hard to get out of the plastic clips?
Re: 93 Spring Project [Re: 5150] #803626 04/08/07 10:24 PM
Sinkut_Laker Offline
Dunno about those brakelines, but, man, now is the time to make sure your wiring/fuel lines and everything else to do with the fuel pump/tank is in tiptop shape.
Scotty
1990 4X4 Pickup V6
390 000 KM
Tired engine, 4.10s, and 31" tires
Dog, Canoe, ATV
Re: 93 Spring Project [Re: Sinkut_Laker] #803627 04/08/07 11:20 PM
5
5150 Offline OP
Thanks, I did all the fuel lines last year and man I wish I had taken the box off instead of dropping the tank.
Re: 93 Spring Project [Re: 5150] #803628 04/09/07 03:33 AM
O
oltrout Offline
shes got the cancer pretty good....i took on a project like this bout 2 years ago...fenders are pretty cheap...65bucks a piece...back of the cab corners on mine were gonzo....i didn't replace the whole sides...just cut out the cancer, fiberglassed it all in and did the body work on top of it...its holding up fine i wouldn't mind knowing what sides are worth tho ....i'm down on the cape...
Re: 93 Spring Project [Re: oltrout] #803629 04/10/07 10:21 AM
5
5150 Offline OP
There is a guy in Bridgewater who sells the fiberglass sides for 200 a piece. I think his name is Blair Moland. I am waiting on a call from wolf steel for the cab corners. They had problems with the last run and had to restamp them. I have new fenders for the front waiting to go on. I ran new brakelines yesterday and once I put one more coat of paint on the frame the new shocks will go on. Need some nice weather ha ha
Re: 93 Spring Project [Re: 5150] #803630 04/10/07 01:35 PM
A
allochris Offline
I just did the same thing you are going to do about 3weeks ago due to my 16yrs old rusty brakeline leakage right btwn the gas tank & the frame rail. Everything is super easy when your bed is off. (it's worth the effort to remove it).
Since you are replacing those 2 brakelines along the frame rail from the front to the back, just cut your brakelines with a cutter about 1/2" from the fittings. Using a socket/rachet to undo the fitting, you are almost garantee not to strip them etc.
To pop out your old brakelines from the framerail, just use a flathead screwdriver & pry them away from the clip.
At the same time, you might as well clean/paint the area around/on top of the gas tank. You could even tap in a fuel pump kill switch or something at the same time while you have access to it!
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: 93 Spring Project [Re: allochris] #803631 04/13/07 02:01 AM
5
5150 Offline OP
This is the final coat of paint, installed the shocks, new brakelines and the bedsides are off.
Re: 93 Spring Project [Re: 5150] #803632 05/11/07 11:18 AM
5
5150 Offline OP
Just an update on the project. Hopefully it will be done soon
Re: 93 Spring Project [Re: 5150] #803633 05/11/07 11:45 AM
subliminaltrips Offline
looks like you have a little work to do, good thing you are doing it the right way. i just picked up an 88 turbo 4 runner that needs the same kind of tlc.
Re: 93 Spring Project [Re: 5150] #803634 05/11/07 09:36 PM
yotaman7 Offline
Lookin good! So where'd you end up gettin the bed sides from and what did they run ya?
"4X4 in upper case is $X$" Quoted from http://4crawler.com/4Runner.shtml
'00 tacoma 4WD---Sold to Toyota
'93 pickup 2WD
'85 pickup 4WD
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6408 MB (Peak: 0.7658 MB) Data Comp: Off Server Time: 2026-05-29 18:59:15 UTC
