ICM harness connector on SOHC V6 #803938 04/09/07 04:27 PM
A
a1966f100 Offline OP
The 3 harness connectors on the ignition control module (top rear of intake) on my 1997 Rodeo are loose causing no starts and cut offs. I've tried tightening the individual terminals and retaping the harness just behind the connectors but I still don't get a tight connection. I can start the engine and barely flex the harness at the ICM and it dies. Has anyone else seen this? Can I get a new harness or connectors?
Thanks!!!
19644speed
Re: ICM harness connector on SOHC V6 [Re: a1966f100] #803939 04/09/07 10:49 PM
TrailMystic Offline
I had to replace my entire harness. The dealer said it was an issue that comes up now and then. Same thing - it would cut off when I flexed the harness upward. Unfortunately, a new harness costs $500. I hope you can fix yours.
Pete
'01 Rodeo Sport, 5 Speed Softie, Indy 4X rocker bars, OME 912's, Rancho 9000X's, Superwinch hubs, custom tube bumper with Warn 9000i , Flowmaster 50, TeraLow t-case gears, ARB front & rear lockers, TrXus MT's, Sway bar disconnects
Re: ICM harness connector on SOHC V6 [Re: a1966f100] #803940 04/12/07 04:17 PM
SteveV Offline
I've restored many older cars that have had harness/connector problems. I would start with a local junkyard and get yourself another ICM and as much length of the needed section of harness from the donor vehicle as you can get. I would start with just swapping your ICM with another and checking to see if that solves your problem. You can have a crack somewhere in the ICM or in its connector and thus you think your harness is bad. If that doesn't solve things then you can carefully mark the location of each wire and pin and dremel all of the plastic away so that you are just left with the individual wires and pins. You can check each pin and wire and hook them up one by one. If that works you can then inject some silicone around everything and it will be good to go. As a last resort you should cut off your harness near the connector and splice in another from a donor. Use solder and heat shrink tape on each wire. Don't cut the wires short, instead try to make your new harness longer so that you'll have less stress on the wires when you're done. Good luck!
1997 Trooper
2002 Rodeo
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5934 MB (Peak: 0.6468 MB) Data Comp: Off Server Time: 2026-06-20 18:59:14 UTC
