78 jeep cherokee filter #803951 04/09/07 04:51 PM
doublediamonds Offline OP
just wondering if anyone knows if there is a in tank fuel filter for a 1978 jeep cherokee 4 door with a 360 v8 2 barrle carb, my jeep drives about 2 miles then shuts off, my starter still turns it just wont start,if i let it set for a couple of hours it will start and run another about 2 miles, i replaced the fuel pump (went electric about 5 psi), i replaced the distributor, the coil, plugs,battery cables, fuel filter under the hood, any ideas??
If you cant get there in a jeep you probably dont need to get there
Re: 78 jeep cherokee filter [Re: doublediamonds] #803952 04/09/07 10:02 PM
BigJim Offline
I assume it was doing this before doing all the work.. Sounds like a lectric part is heating itself up and stops working. If there is a spark box on that Jeep there is your problem. On cj's and wranglers it is on the drivers fender under the coolant container. Costs bout 20 bucks.
Re: 78 jeep cherokee filter [Re: BigJim] #803953 04/10/07 09:34 AM
yeah it was doing it before all the replacements, they were done in an attempt to fix the problem besides it needed a good tuneup anyways,
Re: 78 jeep cherokee filter [Re: doublediamonds] #803954 04/14/07 03:48 PM
got it running thanks everybody
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.5991 MB (Peak: 0.6546 MB) Data Comp: Off Server Time: 2026-07-16 03:42:05 UTC
