Dana 44 tools needed. #804050 04/09/07 08:15 PM
Cruizin Offline OP
I have pulled many axles when I was a mechanic years ago, but I haven't pulled a dana 44. I have a 2004 Rubicon and would like to know what tools I need and the steps involved. Headed down to Moab soon and would like to have the tools needed. Can any one list these for me so I don't have to actually pull the axle and make a list? Also any tips for disassembly and reassembly.
Thanks
Re: Dana 44 tools needed. [Re: Cruizin] #804051 04/09/07 10:04 PM
BigJim Offline
You don't need a list. Just go outside and see what the size of the bolts is! The axle comes out from the outside of the wheel.
Re: Dana 44 tools needed. [Re: BigJim] #804052 04/10/07 04:44 PM
Cruizin Offline OP
There is a strange star looking nut that looks like I will need a special tool for. Other than that are there any other special tools needed?
Re: Dana 44 tools needed. [Re: Cruizin] #804053 04/10/07 05:49 PM
Brown81CJ5 Offline
If it's a bolt, you will need a torx bit, but any Jeep owner should have a set of those already. If it is the actual nut then you will need a reverse torx bit, which your local auto parts store should have. Other than that you should just need a decent set of tools. Don't forget a cheater bar, but if you have a hi lift the handle works great for that.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: Dana 44 tools needed. [Re: Brown81CJ5] #804054 04/11/07 02:37 PM
superdawg Offline
Those three bolts that hold the unit bearing in are NOT torx, they are 13mm 12 point.
SD
Re: Dana 44 tools needed. [Re: superdawg] #804055 04/11/07 04:10 PM
Brown81CJ5 Offline
my mistake. torx and 12 points are both star shaped.
Gun it and run it!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6082 MB (Peak: 0.6772 MB) Data Comp: Off Server Time: 2026-06-10 07:26:24 UTC
