Noise on acceleration #804211 04/10/07 04:44 PM
MARKB Offline OP
I recently purchased a 97 T-100 SR5 4wd. It has a noise I can't track down. As I accelerate from a stop there is a "Rattle" that sounds like a loose heat shield. I have checked all the one's I can see and all seem to be tight. I have also replaced the muffler. It increases with RPM. But it stops when I'm just cruising.
Any ideas will be welcome. TIA
Mark
Re: Noise on acceleration [Re: MARKB] #804212 04/10/07 08:44 PM
ErikB Offline
Toyota Moderator
Check the heat sheild(s) near the firewall. They frequently develop small cracks and make noise. The easy fix is a hose clamp around the shield.
http://home.4x4wire.com/erik
Re: Noise on acceleration [Re: ErikB] #804213 04/10/07 11:32 PM
MARKB Offline OP
Thanks,
I assume you mean the shield on the crossover pipe. I'll get a couple of clamps tomorrow and give it a try.
Re: Noise on acceleration [Re: MARKB] #804214 04/11/07 06:13 PM
reivertom1 Offline
My '93 has done that for years and I just have lived with it. I might check it out now that I have a clue.
Re: Noise on acceleration [Re: ErikB] #804215 04/12/07 02:10 PM
MARKB Offline OP
I put two clamps on the shield over the crossover pipe AND re-attached the hood to the frame per the FAQ. Not sure which did the trick, but noise is gone!
Thanks
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6035 MB (Peak: 0.6672 MB) Data Comp: Off Server Time: 2026-06-23 04:54:13 UTC
