Noise on acceleration
#804211
04/10/07 04:44 PM
Noise on acceleration I recently purchased a 97 T-100 SR5 4wd. It has a noise I can't track down. As I accelerate from a stop there is a "Rattle" that sounds like a loose heat shield. I have checked all the one's I can see and all seem to be tight. I have also replaced the muffler. It increases with RPM. But it stops when I'm just cruising. Any ideas will be welcome. TIA Mark
Re: Noise on acceleration
[Re: MARKB]
#804212
04/10/07 08:44 PM
Toyota Moderator
Check the heat sheild(s) near the firewall. They frequently develop small cracks and make noise. The easy fix is a hose clamp around the shield.
[Re: ErikB]
#804213
04/10/07 11:32 PM
Thanks, I assume you mean the shield on the crossover pipe. I'll get a couple of clamps tomorrow and give it a try.
[Re: MARKB]
#804214
04/11/07 06:13 PM
My '93 has done that for years and I just have lived with it. I might check it out now that I have a clue.
[Re: ErikB]
#804215
04/12/07 02:10 PM
I put two clamps on the shield over the crossover pipe AND re-attached the hood to the frame per the FAQ. Not sure which did the trick, but noise is gone!
Thanks
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6038 MB (Peak: 0.6674 MB) Data Comp: Off Server Time: 2026-06-07 07:06:16 UTCValid HTML 5 and Valid CSS
