15"x10" rims on a Gen I? #804372 04/11/07 04:31 PM
Fleabag Offline OP
I have found a set of 15" rims, 10" wide with 3and3/4" back spacing. Would these rims fit without using spacers on my GenI? I just thought I could try these with 33s.
Strangers have the best candy
Re: 15"x10" rims on a Gen I? [Re: Fleabag] #804373 04/11/07 06:55 PM
cap510 Offline
That's exatly the same wheel setup I have in my 95SR, I think they will stick out quite a bit on your truck. Here is a pic of them on 37x12.5 MTRs:
[b]94/95 Montero SR "rockcrawler"
Riding on 37" MTRs
Re: 15"x10" rims on a Gen I? [Re: Fleabag] #804374 04/11/07 08:37 PM
The rims will fit. What size tire are you considering? How much tire outside the wheel well are you willing to live with? I used a combination of 15x8.5 in front and 15x10 in back (both rims with 4" backspace) with 33x12.5's to achieve the same tire outside the wheel well, about 1.5 inch. In the front wheel well, you'll need to trim or bend out the front splash lip and trim the bumper ends. I didn't have any problem with the rear wheels stuffing into the well, with no body lift. However, using the 3.75 inch BS, you might rub a little on the outside interior of the wheel well. A body lift solves most issues above, with the exception of the bumper ends. I'll post some pics of my setup later. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
32's on 15 x 8's with 3.25" BS - too much offset, looked good, rode horrible
Re: 15"x10" rims on a Gen I? [Re: Fleabag] #804375 04/11/07 08:40 PM
Alex Kogan Offline
These are bit wide for regular width (12.5) 33s IMHO. The backspacing is also pretty bad. It will most likely rub with such little backspacing quite a bit. Spacers will only make it worse.
08 PowerWagon (stock!)
Re: 15"x10" rims on a Gen I? [Re: Alex Kogan] #804376 04/11/07 09:41 PM
Fleabag Offline OP
I plan on getting the Roger Brown 2"lift kit *** WHEN he gets back as their website is on vacation right now <img src="/forums/images/graemlins/angry.gif" alt="" /> ***
But for some strange reason it has been hard to source out a set of 15x8 rims around here and I just happened to find someone selling these 15x10s with/without Toyota axles.
If I could find a set of 15x8 rims for some 33s, I will be happy.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6082 MB (Peak: 0.6750 MB) Data Comp: Off Server Time: 2026-06-07 07:02:14 UTC
