Gen II Limited - Looking to buy #804488 04/11/07 08:37 PM
2
2timer Offline OP
Beautiful 2tone blue/silver with 180K miles.
Anyone know if the motor is more or less desirable than earlier years?
Butterfly valve a problem?
T Belt has just been replaced as has brakes and tires. Any major problems to look out for in this year other than the usual checks?
What years did Mitsu make Gen IIs with the squarish wheel well molding?
Thanks. Looking forward to upgrading my '91.
Re: Gen II Limited - Looking to buy [Re: 2timer] #804489 04/11/07 08:45 PM
What year & model are you looking at?
Re: Gen II Limited - Looking to buy [Re: off-roader] #804490 04/11/07 08:56 PM
CapnCrunch Offline
Ditto. You're asking about details for a particular year but you never mention the year.
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
Re: Gen II Limited - Looking to buy [Re: CapnCrunch] #804491 04/11/07 08:59 PM
I think in 98 they did the non-clad fender flares. Anyone with a GEN II 1/2 want to speak up?....Russ?, Toasty?, Angelo?
Re: Gen II Limited - Looking to buy [Re: 2timer] #804492 04/11/07 09:16 PM
2
2timer Offline OP
It is a '99. Didn't know Gen IIs were made that late.
Re: Gen II Limited - Looking to buy [Re: 2timer] #804493 04/11/07 09:19 PM
Angelo Offline
What are squarish wheel well moldings? <img src="/forums/images/graemlins/ignore.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> Just givin ya a hard time. The Gen II.5 had the flares built into the body starting in 98 til 2000. The gear ratio in those are 4.27, plus some of the later year Gen II's.
There is a post recently about how someone on here hates the 3.5 motor. Granted, they are difficult to work on, but rarely need work if you maintain it. I love the motor compared to the 3.0, alot stronger, but some like the older 3.5 motor then the newer 3.5 motor. They are both great motors with a solid transmission (guess I should keep my mouth shut about that one, but that was my fault). With the right gears in them, they will last! More and more people on the wire, atleast the Mitsu guys are starting to trade/ add to their Mitsu line-up. They either have a Raider or and older Montero that is getting too old and they next buy is the SR. They are wonderful trucks and more and more people are starting to pimp them out with crazy mods!!!! Just check the records and the condition of the motor, tranny and such. Good luck!
Angelo
Re: Gen II Limited - Looking to buy [Re: Angelo] #804494 04/11/07 10:06 PM
justice Offline
If youre looking at a 99 the butterfly valves will not be a problem. Those valves were in the DOHC 3.5 available only in the 94-96 SR models.
Re: Gen II Limited - Looking to buy [Re: justice] #804495 04/12/07 03:31 PM
W
Winston Offline
It should also be a SOHC which will reduce potential problems.
'90 Montero XLS (Sold, sadly)
'95 Montero LS 160k
'03 Montero Limited 30k
Re: Gen II Limited - Looking to buy [Re: 2timer] #804496 04/12/07 11:52 PM
87Montero Offline
Are we talking a 99 sport? I didn't know the 'fullsize' montys had a 'limited' edition.
Re: Gen II Limited - Looking to buy [Re: 87Montero] #804497 04/13/07 12:19 AM
Scottie2113 Offline
the gen II.5 monteros weren't badged as LS or SR, they were badged as limited
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6399 MB (Peak: 0.7637 MB) Data Comp: Off Server Time: 2026-10-26 03:51:15 UTC
