Pitman Pullers? #804512 04/11/07 09:57 PM
LittleMuleCJ7 Offline OP
G'day Jeepers.
Quick question. I have been using the AmPro pitman puller in an attempt to remove the current pitman. I have only moved the pitman arm about 1/4 of the way off, and I have broke 2 pullers.
Any suggestions on a different brand or type of puller? I think this is the first time this arm has had removal attempted since it went on in 82!
Thanks in advance.
OIIIIIIIO
82' CJ-7, SOA and many other goodies.
Re: Pitman Pullers? [Re: LittleMuleCJ7] #804513 04/11/07 10:02 PM
bhartwell59 Offline
i've always been told to do a soaking shot of liquid wrench (overnight) then pulling/wrenching and tapping with a hammer at the same time.
4.2 '87 yj, 263,000 miles, mopar mpi, 33" mud bfg, skyjacker 4", 3.73 gears, arb lockers-f and r., tom wood's 2.07 shaft conversion, tom wood's hd driveshaft, magnaflow/custom exhaust, 4wd bumper/swing-out tire carrier
Re: Pitman Pullers? [Re: LittleMuleCJ7] #804514 04/11/07 10:04 PM
BigJim Offline
Howdy LM. When I have a tight fit I tighten the puller to what I think is it's limit and then give it a WHACK with a bfh. This usually loosens the part to where I can again tighten the puller and give her nother WHACK! The sudden impac is a wonderful thing to see.
Re: Pitman Pullers? [Re: BigJim] #804515 04/12/07 01:52 AM
Thanks Guys.. still working on her. I gave her one round of a good soaking and let her sit about 2 hours. Now I'm tightening the puller to what appears to be its limit (slight flexing showing on the ends) and giving her a good whack with a BFH! <img src="/forums/images/graemlins/kewl.gif" alt="" /> The I am loosening the puller and slightly rotating it to grab at another point and following suite with another whack! So far.. still workin' it. <img src="/forums/images/graemlins/shame.gif" alt="" /> No beer till its off. Heading back to work on it!
Lil'Mule
OIIIIIIIO
Re: Pitman Pullers? [Re: LittleMuleCJ7] #804516 04/12/07 01:59 AM
HA! Scratch that last post. I went back out there, hosed her down with some PB Penatrating Catalyst, maxed out the puller, got my biggest hammer out and gave one huge WHACK and the son'***** flew off! <img src="/forums/images/graemlins/nana.gif" alt="" />
Thanks for the input fellas.
OIIIIIIIO
Re: Pitman Pullers? [Re: LittleMuleCJ7] #804517 04/12/07 03:01 AM
9
93yj Offline
AmPro tools are JUNK JUNK JUNK...it's a good thing they come with a lifetime warranty. Good example of "you pay for what you get".
I used to laugh when a customer would come in with a broken AmPro ratchet all pissed off. I'd think to myself, come on guy, you payed 10$ for that thing. What do you EXPECT?!!!
Then again, 28$ was a lot a money for a rotor (for example) to the rednecks. They'd say. "28 dollars!!!???". Heh. Unbelievable.
Re: Pitman Pullers? [Re: 93yj] #804518 04/12/07 03:27 AM
RalkClimber Offline
What about heating it with a propane torch?? I've heard that works really well. Of course you have to be careful not to pop the seal. <img src="/forums/images/graemlins/smile.gif" alt="" />
Ralk
'97 Jeep Wrangler 2.5L 105k Miles
Recent Replacements: Cam Shaft, Lifters, Push Rods, Distributor, Dist. Cap/button, Plugs, Oil Pump, Oil Sending Unit, Timing Chain/sprokets, and all associated gaskets.
Re: Pitman Pullers? [Re: LittleMuleCJ7] #804519 04/12/07 04:24 AM
BobRowe Offline
Sometimes, with Jeeps, you just have to use the subtle approach! <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Pitman Pullers? [Re: BobRowe] #804520 04/12/07 01:17 PM
I pulled out my little torch and could not locate my nozzle to attach and fire it up. Not wanting to make another trip out I went the old way of doing things. As bhartwell59, BigJim, and BobRowe all agree... soak it with a catalyst of some sort to break up rust and the sort, put some pressure on it (in this case a pitman puller) and giver her some persuasion with a good WHACK and she'll move. <img src="/forums/images/graemlins/kewl.gif" alt="" />
OIIIIIIIO
Re: Pitman Pullers? [Re: RalkClimber] #804521 04/12/07 01:40 PM
DBL_DTY97TJ Offline
That's worked for me on several things. Would like an oxy torch though. If you're pulling the pitman, unless it's to put a longer one on, chances are you're not too worried 'bout the seal. <img src="/forums/images/graemlins/cheers.gif" alt="" />
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.005s) Memory: 0.6355 MB (Peak: 0.7593 MB) Data Comp: Off Server Time: 2026-10-27 00:25:28 UTC
