38mm weber carb again?
#804610
04/12/07 05:14 AM
Anyone ever run into any issues with there 38mm weber? Just looking for some info before I install this bad mofo this weekend.
Re: 38mm weber carb again?
[Re: Lil_Jon]
#804611
04/12/07 05:45 AM
http://www.redlineweber.com/ Click on the 'tech information' link on the left. Should have all the info you will need. <img src="/forums/images/graemlins/kewl.gif" alt="" /> -Scerb
[Re: Scerb]
#804612
04/12/07 02:09 PM
the only thing i didnt like about a carb is the fact it doesnt like upward slopes but ive since been able to tune it a bit better using a 1-4 psi regulator from summit and i dropped my float level down about 5mm from the factory preset level. i run the truck at about 1 psi in the woods and then adjust it to 2 psi on the street, i have a gauge which makes it easy. heres my thread. http://www.4x4wire.com/forums/showf...mp;amp;sb=5&o=14&fpart=1
[Re: Lil_Jon]
#804613
04/12/07 02:57 PM
What other mods are on your motor? I've used the 32/36 and 38mm - couldn't feel a difference on a mildly mod'd motor between the two, unless I went to the gas pump!
22REturbo.net 1988 4Runner 22RTE core, turbocharged, megasquirted...
[Re: dcg9381]
#804614
04/12/07 03:15 PM
ive got a complete engnbldr street rv,os ss valves with his 261c cam ,quench set at .007" thorley header 2/1/2 inch pipes. 5.29s locked on 35x15.5 tsl sx's
its real torquey , my next mod will be the msd ignition.and an lce adjustable cam gear. i get about 12mpg now,i think it runs a little rich on the mains still so im going to run a smaller main jet its a 170/170 factory, im going to try a 165 on both sides. i think the smaller jet will help with mileage. and help me get a little more power in the mid rpm range. now it kicks hard off idle to about 3000 rpm it makes its best power down low which is what i like but id like to help it pull a little higher like 4000 or so.
[Re: subliminaltrips]
#804615
04/13/07 06:29 AM
12 MPG!!! that sends chills up my spine. something isn't right. i cant imagine getting that kind of mileage out of my 22r. the weber can't suck that much gas can it? i get anywhere from 17-24 mpg depending on the type of driving i'm doing and which way the wind is blowing lol.
[Re: 87Toy4x4]
#804616
04/13/07 06:00 PM
i get anywhere from 17-24 mpg depending on the type of driving i'm doing and which way the wind is blowing lol. Fawk man, you ever gotta downshift when the wind picks up?? IT SUCKS! <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: 87Toy4x4]
#804617
04/13/07 07:33 PM
Over the past few years, my 22r with the Weber 38 has averaged; Off-road days (including to & from trailhead) 16mpg, Daily commute (35 miles round trip) 16.5 winter, 17.5 summer, Highway trips 18. I get these numbers very consistently.
84 4RUNNER,22R,HEDMAN,WEBER 32/36,Davis Unified Ignition,33" BFG
