Antenna Mounting #804618 04/12/07 05:33 AM
thefarky Offline OP
Where is the best and/or place to mount a CB antenna on my '95 Toyota Pickup?
1995 Toyota Pickup, SR5 3.0V6, 31X10.50 Mud Tracs
Re: Antenna Mounting [Re: thefarky] #804619 04/12/07 07:12 AM
Scerb Offline
Supposedly you get the best signal as far away from the cab as possible. So on either bumper or on the bedrail, or on top of the cab. I welded a tab to the top of my bedrail near the tailight.
-Scerb
Re: Antenna Mounting [Re: Scerb] #804620 04/12/07 01:45 PM
TexJeff87 Offline
how Roger does it
Hey, look...I beat Roger to the punch!!! Woo-hoo!!!
<img src="/forums/images/graemlins/lol.gif" alt="" />
If Mad Max had a 4runner...
Re: Antenna Mounting [Re: Scerb] #804621 04/12/07 01:58 PM
OOP'S Offline
-Scerb
I was told by the CB shop that the best place was in the middle of the top, so that is where I mounted mine.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Antenna Mounting [Re: OOP'S] #804622 04/12/07 04:11 PM
Z
zachtheterrible Offline
You want your antenna to be as high up as possible with the largest ground plane possible. A ground plane is basically anything connected to the - side of your battery (the truck body). So your antenna should be right in the middle of the largest ground plane, such as your roof. You should also get an SWR meter to match the antenna to the CB
1984 Toyota Pickup
22R, carbureted
Aussie lockers front n rear
4.88 gears
35's
Full exo
Marlin crawler
Re: Antenna Mounting [Re: zachtheterrible] #804623 04/12/07 09:31 PM
thefarky Offline OP
What's the best way to mount it onto the top of the cab?
Are the cheap magnetic ones any good?
Also, where is the best place to run the wire? Through the rear window?
Re: Antenna Mounting [Re: thefarky] #804624 04/12/07 09:38 PM
Scerb Offline
No, the magnetic ones absolutely suck. It was useless on trails as it always got knocked off... thats NH trails though. On the road it worked fine..
Re: Antenna Mounting [Re: Scerb] #804625 04/12/07 10:32 PM
ldivinag Offline
my cheapie $20 walmart one has worked well.
the trick is tuning the antenna to the radio with an SWR meter...
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Re: Antenna Mounting [Re: ldivinag] #804626 04/12/07 11:12 PM
Talon84X4 Offline
I've got one mounted on the cab, top and centered, works great <img src="/forums/images/graemlins/kewl.gif" alt="" />
As for mounts, there's lots of ways to do it, hardmounting is usually best for reception, my antenna came with the hard mount, had to drill a whole through the cab for the coax, but the antenna can be removed and a little cap to cover the coax connection when not in use
'84 PU low & slow
Central Valley Crawlers
Re: Antenna Mounting [Re: ldivinag] #804627 04/13/07 01:56 AM
YOTA88 Offline
the man's right! tuning is key. i work with truck drivers who have put cheap units in their rigs and work out fine as long as they're tuned correctly. i've been told that you want at least 2/3's of the antenna to be above your cab. that's how one of my drivers installed and tuned mine and i've had no problems so far(3+ years with 4 different cb's and the same cheap antenna).
SAS88TOY, caged, lockered, Longfielded, etc. etc. etc. blah blah blah!!!
2005 Tundra Quadcab.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6365 MB (Peak: 0.7598 MB) Data Comp: Off Server Time: 2026-06-17 13:40:21 UTC
