Auto trans goint to neutral
#804846
04/12/07 06:25 PM
I drive a few blocks and the auto trans goes into neutral and won't shift. I turn it off, leave it off fer a couple of minutes, and again I can drive a few more blocks and it goes into neutral again. I also hear like a slight grinding noise coming from the trans. It will shift OK when it runs. Any ideas?
1985 Toyota 4x4 4Runner. 1989 Suzuki Sidekick 4x4.
Re: Auto trans goint to neutral
[Re: maraguez]
#804847
04/13/07 06:25 AM
Do you mean the shifter is physically slipping out of drive & into neutral? Or are you manually shifting into neutral & it won't shift back into drive?
4xGeek (Chris) '97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc... No longer stuck in SoCal!!
[Re: maraguez]
#804848
04/13/07 02:08 PM
Toyota Moderator
My first thought would be to check/adjust the shift rod adjustment near the firewall.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.5917 MB (Peak: 0.6447 MB) Data Comp: Off Server Time: 2026-11-03 17:46:04 UTCValid HTML 5 and Valid CSS
