will not start #804858 04/12/07 07:50 PM
Randolph2244 Offline OP
ok, i just purchased my nice 1992 wrangler drove it home, parked it. started it up the next day. Today, i tried to start it and it wouldnt stay running. it idled so rough that it would die every time, and backfire. Now after trying to start it for a while it will not crank at all. nothing.
Re: will not start [Re: Randolph2244] #804859 04/12/07 09:17 PM
BigJim Offline
Take it back! Most if not all vendors will honor a 2 day warranty.
Re: will not start [Re: BigJim] #804860 04/12/07 10:07 PM
it was purchased from a private seller, returning it is not an option.
Re: will not start [Re: Randolph2244] #804861 04/12/07 10:52 PM
hudek Offline
did you car fax it? maybe you should try even calling them and asking whats up.
Re: will not start [Re: Randolph2244] #804862 04/13/07 11:00 AM
doublediamonds Offline
so when you jump it it wont even turn over?? check your electronics it sounds like something is either grounded or gone bad, start with the ignition system first and check it out like the spark, coil, distributor and so on
If you cant get there in a jeep you probably dont need to get there
Re: will not start [Re: doublediamonds] #804863 04/13/07 05:03 PM
ok, i just replaced the dist cap, rotor, wires and plugs...it started and idled for about 10 secs and then got rough again and died. now it will not start again. am i missing something here?
Re: will not start [Re: Randolph2244] #804864 04/13/07 10:28 PM
G
Greg2000 Offline
Ok so you checked some stuff. It sounds like it is getting spark to start it just won't idle. Correct? Did you check the fuel side of the equation. Is it getting gas and is it getting gas all the time. Did you run out of gas? Did you get a bad take of gas? Check everything fuel related then let us know.
<img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: will not start [Re: Greg2000] #804865 04/13/07 11:41 PM
BigJim Offline
Greg I personally have never seen a tank of gas that wouldn't run..
May be the carb choke is doing either too much or not enough.. Does the choke pull off? Is it on full choke when it DOES start? Do you know HOW to start a carbed engine?
Re: will not start [Re: BigJim] #804866 04/14/07 12:07 AM
playinmud Offline
BJ i didnt know the 92's were still carbed, well i guess you learn something new every day
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
Re: will not start [Re: BigJim] #804867 04/14/07 12:25 AM
G
Greg2000 Offline
Big Jim
You are right and wrong. In theory gas should burn due to its nature. But, as is sometimes the case water gets mixed with the water the gas then will not burn as well as it should due to the water being injected into the carb or fuel injection. Enough water and it won't run. So one needs to get rid of the water. By either dumping the gas or using some other chemical that will evaporate the water away from the gas. <img src="/forums/images/graemlins/shame.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6339 MB (Peak: 0.7408 MB) Data Comp: Off Server Time: 2026-06-24 16:04:34 UTC
