will not start
#804858
04/12/07 07:50 PM
ok, i just purchased my nice 1992 wrangler drove it home, parked it. started it up the next day. Today, i tried to start it and it wouldnt stay running. it idled so rough that it would die every time, and backfire. Now after trying to start it for a while it will not crank at all. nothing.
Re: will not start
[Re: Randolph2244]
#804859
04/12/07 09:17 PM
Take it back! Most if not all vendors will honor a 2 day warranty. Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: will not start
[Re: BigJim]
#804860
04/12/07 10:07 PM
it was purchased from a private seller, returning it is not an option.
Re: will not start
[Re: Randolph2244]
#804861
04/12/07 10:52 PM
did you car fax it? maybe you should try even calling them and asking whats up.
Re: will not start
[Re: Randolph2244]
#804862
04/13/07 11:00 AM
so when you jump it it wont even turn over?? check your electronics it sounds like something is either grounded or gone bad, start with the ignition system first and check it out like the spark, coil, distributor and so on
If you cant get there in a jeep you probably dont need to get there
Re: will not start
[Re: doublediamonds]
#804863
04/13/07 05:03 PM
ok, i just replaced the dist cap, rotor, wires and plugs...it started and idled for about 10 secs and then got rough again and died. now it will not start again. am i missing something here?
Re: will not start
[Re: Randolph2244]
#804864
04/13/07 10:28 PM
ok, i just replaced the dist cap, rotor, wires and plugs...it started and idled for about 10 secs and then got rough again and died. now it will not start again. am i missing something here? Ok so you checked some stuff. It sounds like it is getting spark to start it just won't idle. Correct? Did you check the fuel side of the equation. Is it getting gas and is it getting gas all the time. Did you run out of gas? Did you get a bad take of gas? Check everything fuel related then let us know. <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: will not start
[Re: Greg2000]
#804865
04/13/07 11:41 PM
Greg I personally have never seen a tank of gas that wouldn't run.. May be the carb choke is doing either too much or not enough.. Does the choke pull off? Is it on full choke when it DOES start? Do you know HOW to start a carbed engine? Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: will not start
[Re: BigJim]
#804866
04/14/07 12:07 AM
BJ i didnt know the 92's were still carbed, well i guess you learn something new every day
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
Re: will not start
[Re: BigJim]
#804867
04/14/07 12:25 AM
Big Jim You are right and wrong. In theory gas should burn due to its nature. But, as is sometimes the case water gets mixed with the water the gas then will not burn as well as it should due to the water being injected into the carb or fuel injection. Enough water and it won't run. So one needs to get rid of the water. By either dumping the gas or using some other chemical that will evaporate the water away from the gas. <img src="/forums/images/graemlins/shame.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
