Re: will not start [Re: Greg2000] #804868 04/14/07 01:16 AM
BigJim Offline
Yeah I was missing a few brain parts wasn't I? Nope it should be a fuelie.
As for water and gasoline mixing.. not without some soap it won't.. The water goes to the bottom of the tank and is pumped sporaticly depending on the amount of water in the tank. Water was not mentioned..BAD GAS was.
Re: will not start [Re: BigJim] #804869 04/14/07 02:25 AM
G
Greg2000 Offline
Jim
The water being sporaticly pumped from the tank can cause rough idle. That is something that should be looked at. Gas is not pumped from the top of a tank into your car it is pumped from the bottom i.e. causing more water than gas to go into your tank. Of course this is assuming that the place giving the gas has a leak in there system
Re: will not start [Re: Greg2000] #804870 04/14/07 02:34 AM
mmcpeck Offline
I have to agree with Jim, that it is not a fuel issue, at least not with the fuel in the tank, especially since he drove it home, if there were contaminated gas in it, he would have seen this problem as soon as he accelerated, especially with a carbed engine. Enough water to cause this problem in a car is very rare, it would have to have been sitting for a years and would have to have been E10 fuel, and even then I don't know. Extremely huge problem with boats but very rare on cars.
I'd agree though that is is a fuel problem as far as fuel being supplied to the engine, I would start off by checking the choke and look for any vacuum leaks.
Re: will not start [Re: mmcpeck] #804871 04/14/07 06:27 AM
BobRowe Offline
It might also be a clogged vent on the tank. I've had that happen on a few cars. Sometimes, if a vent is glogged, the engine will run until a vacuum builds up in the tank. If it dies after running a while (but not long enough to heat up ignition parts), that could be the problem. Easy enough to check, After it dies, immediaely take the gas tank cap off and try to restart the engine.
Re: will not start [Re: Greg2000] #804872 04/14/07 04:42 PM
Randolph2244 Offline OP
its a fuel injected engine, when i try to start it i can smell the fuel so i know it is getting it..i just replaced the fuel filter and it once again idled for about 2 seconds and then died. It tried to turn over twice afterwards and still will not continue running. What kind of chemical can i put in to evaporate the water, the truck did sit up for a year prior to my purchase, or so im told.
Re: will not start [Re: Randolph2244] #804873 04/14/07 05:02 PM
my father posed the idea that it might have jumped time, does that sound like a possibiliy? if so, how difficult of a repair is that to undergo? i have yet to do it to a jeep wrangler
Re: will not start [Re: Randolph2244] #804874 04/14/07 05:50 PM
okay, sheer dumb luck got me to stumble on this answer....i was thinking maybe the coil was goin badd, so i was looking at to get an idea of what i needed to order and i noticed the wires on the coil's blade connectors were loose, so i got the pliers and tightened them up...what do you know it starts and runs with no problems.
Re: will not start [Re: Randolph2244] #804875 04/14/07 06:51 PM
cjensen Offline
GOOD for U!
I hope now u'll be able 2 enjoy your new to u jeep.
Warmest Hello and glad to hear it worked out.
C. <img src="/forums/images/graemlins/wink.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6265 MB (Peak: 0.7378 MB) Data Comp: Off Server Time: 2026-06-24 16:03:44 UTC
