HELP with diff?!! #804969 04/13/07 07:37 AM
santacruzT100 Offline OP
Today I was replacing my rear pinion seal and I need to set the preload.....but I need to know how many spider gears my rear diff. has? 2 or 4?
I've got a 95 t100 4wd with 3.4l and stock(4.10) gears..thanks for the help
White '95 T-100 dx 4wd. Auto.
3.4l v6 w/K&N air filter
285/75r16 BFG's Mud on 16x8 American Racing black Fuel wheels.
Sway-a-way torsion bars, soon to add rancho 9000x
Re: HELP with diff?!! [Re: santacruzT100] #804970 04/13/07 02:10 PM
ErikB Offline
Toyota Moderator
2 spiders front and rear, but I don't know what that has to do with the preload... <img src="/forums/images/graemlins/confused.gif" alt="" />
http://home.4x4wire.com/erik
Re: HELP with diff?!! [Re: ErikB] #804971 04/13/07 05:53 PM
Awesome!!! thanks. I am using the Chilton repair manual to repair/replace my leaking pinion seal and Chilton says in step 8 of To Install: "Check the drive pinion preload with a torgue wrench. For Pick-Ups and 4Runners, correct torque is 8-11 inch lbs.(0.9-1.2 Nm) for 2-Spider gear differentials and 4-7 inch lbs. (0.4-0.8Nm) for 4-Spider gear units. Land Cruisers should be between 6-9 inch lbs.(0.6-1.0Nm)"
thanks again <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: HELP with diff?!! [Re: santacruzT100] #804972 04/13/07 07:08 PM
ErikB Offline
Toyota Moderator
Well you don't have the same rear diff as a mini pickup, 4runner, or landcruiser. I would go with the heavier preload number for this diff. I'll see if I can find an online FSM for you...
Re: HELP with diff?!! [Re: ErikB] #804973 04/13/07 07:25 PM
ErikB Offline
Toyota Moderator
Here you go, see the bottom of page SA-168:
http://www.deserted1.com/FSM/Repair_Manual/03tacoma/sa/rdc3rz5v/reas.pdf
The open Tacoma diff is the same as the T100 and Tundra.
Re: HELP with diff?!! [Re: ErikB] #804974 04/13/07 08:05 PM
this is my axle code if it helps C/TR 04/FF13. A/TM A10A/A340F.....Thanks for the help so for the pinion preload i should use 8-11inch lbs. instead of 4-7 lbs.?
Re: HELP with diff?!! [Re: santacruzT100] #804975 04/13/07 08:58 PM
BamZipPow Offline
From ErikB's webpage... <img src="/forums/images/graemlins/wink.gif" alt="" />:D
http://home.4x4wire.com/erik/diffs/#rear
Re: HELP with diff?!! [Re: BamZipPow] #804976 04/22/07 06:15 AM
Thank you guys for all the help everythin went well!!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6242 MB (Peak: 0.7065 MB) Data Comp: Off Server Time: 2026-05-29 14:41:17 UTC
