Found out my truck is a BOGGER! #805088 04/13/07 09:47 PM
kuso Offline OP
...while driving down the road that is. <img src="/forums/images/graemlins/notooth.gif" alt="" />
When in the lower RPM range, the truck bogs down and really takes its dear sweet time to pick up speed. It finally hooks up past 3500 RPM. Idle is also rough w/ no stalling...yet.
I'm gonna give the throttle body a good cleaning, along w/ the EGR to see if that helps any. Anything else I should inspect??
Also, it's been leaking fuel on 'n off again, but not all the time. I've got the air intake off and have been inspecting hoses 'n lines for any obvious damage (thought the line to the cold start was the primary culprit), but no luck yet.
Any advice is greaty appreciated! <img src="/forums/images/graemlins/kewl.gif" alt="" />
-kuso <img src="/forums/images/graemlins/shiner.gif" alt="" />
'91 Toyota, X-cab, 3.0, SR5, 4x4, Automatic Leech Tranny, 31" Generics, "KaTooM Carrier" 201K and runnin' smooth!
Many a good man has failed because he had his wishbone where his backbone should have been.
--Unknown
Re: Found out my truck is a BOGGER! [Re: kuso] #805089 04/13/07 11:18 PM
kuso Offline OP
Okay, forget about the bogging. I've got a bigger problem on my hands now thanks to my hands! While installing the fuel line that goes from the cold start injector to the fuel rail, I over tightened the banjo bolt and stripped the threads! <img src="/forums/images/graemlins/frown.gif" alt="" /> <img src="/forums/images/graemlins/barf.gif" alt="" /> So, my question is: Can that hole be re-threaded or am I S.O.L.? What a nice way to spend a day off...ugh.
Thanks,
--Unknown
Re: Found out my truck is a BOGGER! [Re: kuso] #805090 04/14/07 05:31 PM
dogtoy Offline
Buy a plenum off e-bay or something. I see them there regularly and for pretty cheap too! I do not see why you couldn't helicoil the stripped threads but maybe that would effect how the fuel sprays? Might not seat exactly where it is supposed to and cause undesired performance, I do not know, maybe somebody else does.
As far as the bogging is concerned at lower rpm's, classic symptom of a vacuum leak or possibly intake tube cracked, inspect all thoroughly and my guess is you will find the problem.
2014 FJ
Re: Found out my truck is a BOGGER! [Re: dogtoy] #805091 04/15/07 12:06 AM
Squishy Offline
Also check the intake manifold gasket and the plenum gasket. Common failure. I see it quite a bit at the shop. just spray some brake clean on both with the truck running and see if your idle changes on one or the other or both
Justin Morgan-Speed never killed anyone, it's the sudden stop at the end that'll get ya
1988 Toyota 1/2 ton
Solid front axle, locked fore and aft, 35's and 5.29s.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6021 MB (Peak: 0.6590 MB) Data Comp: Off Server Time: 2026-10-24 03:18:15 UTC
