wrangler lift problem #805132 04/14/07 01:23 AM
TooOld4Idol Offline OP
Long story I won't repeat but outlined in another post named LIFT PROBLEM. Anyway, back for help. Severe vibration after 4 inch lift of 99 wrangler 4.0 including pittman arm. Although I was told I needed a slip yoke eliminator here on the forum, 4wheelparts.com manager says don't need slip yoke eliminator to fix the problem because they've never sold a SYE for this particular lift kit. He says the driveshaft shim needs to be adjusted for the pinion angle to correct the vibration. Well, for a layman like me, I have no idea what to do. Can you help with instructions and was this correct info I received? Thanka!
Re: wrangler lift problem [Re: TooOld4Idol] #805133 04/14/07 06:22 AM
BobRowe Offline
If you have regular U-joints on both ends of the drive shaft, then the rear axle shims should be adjusted such that the angle at both ends of the driveshaft is the same, otherwise you will have different rotational velocities. If that doesn't fix our vibration, then rotating the rear pig up will only cause exzcessive wear.
I'd tend to believe the guys here on the forum, not some salesman at a mail order house.
It may be that the lift you installed caused the maximum U-joint angles to be exceeded, causing the vibration. If you currently have a slip yoke, I'd first install a SLE kit -- keep in mind that the reason for doing this is to increase the effective length of the driveshaft. Increasing the distance between the front and rear u-joints will result in lower u-joint angles. After doibg that, ensure that both u-joins are operating at the same angle. That may be enough to stop the vibration. If it still vibrates after installing the SLE kit, then I'd recommend a double-cardan (CV) joint at the front end of the rear driveshaft. Now, with a CV joint, you don't ry to achieve equal angles at both ends of the driveshaft. You adjust the pig such that the pinion points directly at the CV joint. Actually, most people point it one or two degrees off when sitting static. That way, when normal torque is applied to the driveshaft during vehicle operation, it will torque the pig up a little bit, so it's pointing at the front u-joint in a dynamic condition.
Re: wrangler lift problem [Re: BobRowe] #805134 04/14/07 02:30 PM
Thank you Bob. This has been something to deal with when you are not mechanically smart. Always depended on Son, now getting ready for third tour in war. He just doesn't believe a SYE is needed and that was echoed by 4wheelparts. However, it appears by forum feedback that I'm gonna have to buy one whether I like it or not. Problem is installation around here in this rural area. I'm a bit disabled from my own wars during 30 years in military and can't do it so I'll just have to go to the "big city" for install once I figure out what all to buy. Again, thanks for the info.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.5937 MB (Peak: 0.6479 MB) Data Comp: Off Server Time: 2026-06-23 03:12:46 UTC
