Re: Direct Inject [Re: FEF] #805251 04/18/07 09:01 PM
holger Offline
Well, the good part of this is that it's relatively easy to clean the intake stuff. I did it on my Rodeo before, and I think it must be the same for the 3.5DI on the Axiom. Unless the carbon build-up is really nasty one and requires manual scraping.
Oleg
Deceased Rodeo'02 4WD.
Re: Direct Inject [Re: holger] #805252 04/18/07 11:12 PM
FEF Offline
Very true.
In my case, Isuzu recommends I warm it up, pull the plugs, but in cleaner, let set a few hours, fire it up, clean garbage from intake, EGR, and PCV, then change oil (solvent will slip between the rings).
Sure, this is not so bad, given the alternitive. However, the idea of doing this twice a year, due to a design miss, is frustrating.
Again, it could be a lot worse.
"Stubig" - '72 416.141 (U1100) Unimog
"Sassy" - '05 KLR650
"Brody" - '04 Rodeo (It's my wife's, really)
"Candy" - '02 TDI New Beetle (yes, a family of 4 fits inside)
"Twinkie" - '72 Revcon 250 (converting from Olds 455 to 6.5L Diesel)
Re: Direct Inject [Re: FEF] #805253 10/14/07 12:18 AM
Rodayo Offline
I'm just resurrecting this post to provide a possible alternative solution: I was having problems with acceleration and stalling that my mechanic solved by cleaning the carbon build up. He suggested that I regularly use one of the top tier gas brands (go to www.toptiergas.com for more information). Long story short, after a few tank fulls the Rodeo is running as smooth as the day it was built with no stalling or acceleration issues at all.
- Jim
1996 Rodeo - 3.2L, 5sp., ARB Bull Bar, Rancho 9000x, Eclipse sound
2004 Rodeo - 3.5L DI, Auto
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6027 MB (Peak: 0.6726 MB) Data Comp: Off Server Time: 2026-10-22 04:06:55 UTC
