Engieen swap on 4Runner 3vz- e #805304 04/14/07 06:23 PM
4
4Run95 Offline OP
Hi, does anyone have a tip on a good engieen to swap for (not the 5vz-fe)? Om going to use the truck mostly in non-terrain.
Thanks
1995 4Runner 3,0 V6 5-speed
Re: Engieen swap on 4Runner 3vz- e [Re: 4Run95] #805305 04/14/07 07:58 PM
Adam F Offline
Why NOT the 5vzfe? It's a GREAT motor and it bolts right up to your motor mounts and transmission.
Other motor choices are a 7mgte, Chevy 350, Chevy 4.3, or any other motor you want and can buy or build adapters and motor mounts for.
97 4R, stock, daily driver
Re: Engieen swap on 4Runner 3vz- e [Re: Adam F] #805306 04/14/07 08:31 PM
G
Greg_Canada Offline
If you want to go domestic, get a 302.
Small, powerful (esp. if you build it) and compact for a v8. Easy to get to, just find a wreck mustang and buy the adaptors from Advanced Adaptors... you just have to figure out wiring...
89 4Runner
Re: Engieen swap on 4Runner 3vz- e [Re: Greg_Canada] #805307 04/15/07 05:15 PM
4
4Run95 Offline OP
Well, the problem with the 5vz fe is that i live in Sweden and the 4runner import stopped 96 <img src="/forums/images/graemlins/evil.gif" alt="" /> so there are no ones for sale....Where can i get one then? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Engieen swap on 4Runner 3vz- e [Re: 4Run95] #805308 04/15/07 05:46 PM
4
4Run95 Offline OP
BUT the Land Cruiser was imported! Does the 5vz-fe from the land cruiser bolts direct? Does auto/manu matters?
Thanks
Re: Engieen swap on 4Runner 3vz- e [Re: 4Run95] #805309 04/15/07 11:01 PM
Adam F Offline
Any 5vzfe should bolt up. The 3rd gen 4Runner was based on the Land Cruiser Prado 90 series.
Auto/manual is up to you.
Re: Engieen swap on 4Runner 3vz- e [Re: Adam F] #805310 04/16/07 07:03 PM
4
4Run95 Offline OP
Is the swap hard to do?
Is there anything special to think about when doing the swap?
Does the tranny from 3,0 works with the 3,4?
Thanx
Re: Engieen swap on 4Runner 3vz- e [Re: 4Run95] #805311 04/16/07 08:30 PM
Red_Chili Offline
Toyota Section Staffer
It is one of the easier swaps, and your tranny will bolt right up as well as your motor mounts. I would suggest buying a pre-made wire harness from Off Road Solutions.
Give Mike a call. He is busy and will probably have to call you back, but he is a great guy who does very good work. Start your research here:
http://www.offroadsolutions.com/technicalarticles.htm
-Bill
Re: Engieen swap on 4Runner 3vz- e [Re: Red_Chili] #805312 04/16/07 09:42 PM
Kutter Offline
http://www.4x4wire.com/forums/showf...mp;amp;sb=5&o=14&fpart=1
It is a pretty simple swap and be done very quickly if you get all the stuff together before hand. See link above. It may answer some of your questions.
I now have a few thousand miles on my swap and it is super.
1995 4Runner Limited V6 3.4 Liter 5 Speed 4x4
1995 4Runner V6 Auto 2WD
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6263 MB (Peak: 0.7288 MB) Data Comp: Off Server Time: 2026-06-17 10:48:23 UTC
