Gauge Lights, right half died. #805334 04/14/07 08:51 PM
E
evanknight Offline OP
Hey Guys.
A couple months ago, I jumped in my truck, started it, turned on the headlights and took off down the road. about two seconds into that trip the lights on the right half of my gauge cluster went out, everything else was fine. So now, i cant see how much gas I have at night. I wasnt so concerned at the time as i was in a hurry to get condoms and thus had other things on my mind. :-p
Anyway, Is it a serious pain in the arse to figure out if its just a bulb and/or replace it? Its a 92 4x4 pickup, the gauge cluster without the tach.
I searched the forums, but all the gauge stuff i could find pertained to putting in pretty new ones.
1992 22re Toyota 4x4 pickup big speakers, bigger tires. rear ended <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Gauge Lights, right half died. [Re: evanknight] #805335 04/14/07 09:49 PM
A
allochris Offline
search in fsm under electrical for troubleshooting procedure with a MMC sticking in the harness connections to figure out your trouble.
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: Gauge Lights, right half died. [Re: allochris] #805336 04/15/07 12:11 AM
Squishy Offline
For sure check the bulbs. There is only one bulb for each side of the gauge cluster. (Except for the brake light, check engine light, etc.) I like LEDS.
Check out www.superbrightleds.com/mini-wedge.html.
I changed my whole cluster over to LEDS and they rock. You can use any color you want too. You'll need the T3 1/4 mini-wedge.
Justin Morgan-Speed never killed anyone, it's the sudden stop at the end that'll get ya
1988 Toyota 1/2 ton
Solid front axle, locked fore and aft, 35's and 5.29s.
Re: Gauge Lights, right half died. [Re: allochris] #805337 04/15/07 02:03 AM
E
Thanks. I managed to find a '93 FSM, figured itd be close enough, pretty sure its the bulb after looking at it. Now ive just gotta find a weekend and the will to take the damn dash apart and throw in some new bulbs!
man, those FSM's are gold mines, too.
Re: Gauge Lights, right half died. [Re: evanknight] #805338 04/15/07 02:16 AM
87Toy4x4 Offline
it's not bad at all. i can swap instrument clusters in less than 10 minutes. the hardest part is connecting the speedo cable back up, but it's easy when you disconnect it from the firewall to give yourself some extra slack.
Re: Gauge Lights, right half died. [Re: 87Toy4x4] #805339 04/15/07 04:17 AM
wrxnefx06 Offline
I have to do the same thing but my left side is out. I think I want to try a different color.
Re: Gauge Lights, right half died. [Re: 87Toy4x4] #805340 04/15/07 04:54 AM
A
allochris Offline
x2! it?s easier than you think. i think the fsm pics even show you where each clips are located. all it is is just 4 philips and couple bolts to undo the plastic dash. To make it easier unhook to speedo cable from the firewall clip to give you more slack to play with the disconnection-connection of the speedo cable-cluster (while you hand is jam in there...).
Re: Gauge Lights, right half died. [Re: wrxnefx06] #805341 04/15/07 08:00 PM
Squishy Offline
I'm telling ya. Those super bright leds are awesome. <img src="/forums/images/graemlins/smile.gif" alt="" /> I put blue ones in my dash and it turned out pretty cool. I also swapped out the brake light, check engine light, etc. with white leds. They're only a little bit dimmer, but never have to replace and I'm cool with that. <img src="/forums/images/graemlins/kewl.gif" alt="" />
1988 Toyota 1/2 ton
Re: Gauge Lights, right half died. [Re: evanknight] #805342 04/16/07 12:07 AM
E
Man, I love this forum. You guys rock!
Re: Gauge Lights, right half died. [Re: Squishy] #805343 04/16/07 12:12 AM
Elbow_Greese Offline
I went with red in my cluster.
I like it for night driving, easy on the eyes and doesn't mess up night vision <img src="/forums/images/graemlins/kewl.gif" alt="" />
although the "red line" is just more red now <img src="/forums/images/graemlins/lol.gif" alt="" />
Made my turn signal indicators purple! <img src="/forums/images/graemlins/cyclops.gif" alt="" />
each to their own on color.
Very easy change out.
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.005s) Memory: 0.6431 MB (Peak: 0.7636 MB) Data Comp: Off Server Time: 2026-06-07 04:46:25 UTC
