94 ford ranger shuts off by it self?????? #805451 04/15/07 01:19 PM
ctkia Offline OP
i have a 94 ford ranger extnded cab that started acting really wierd. one morning i went out ot start it to let it warm up before i left for work it ran fine for a few minutes the stopped running. i went to start it and it wouldnt i shut the key off then tried to start it and it started again so i left for work it did the same thing 2 more times on my way to work. it has done this continusely since. i was thinking i had a dead spot in the pump motor. oh 1 more thing one of the times it did this i checked the pressure at thwe rail oon the motor and there was pressure there and i forgot i left the key on now correct me if im wrong but the minute i bleed the pressure off in the rail shouldnt the pump of come on?? i had to cycle the key to get the truck to start.
Re: 94 ford ranger shuts off by it self?????? [Re: ctkia] #805452 04/28/07 04:33 AM
Jackyl Offline
have you tried check/replacing your ignition switch. if that is not the culpret id suggest relays or solinoid.
tread light and save our right
'92 Rodeo 3.1 5spd full manual 4x4 w/ Aisin hubs
'87 F-250 460 4spd full manual 4x4 granny low
Re: 94 ford ranger shuts off by it self?????? [Re: Jackyl] #805453 05/07/07 05:08 AM
Hanzo_Steel Offline
Is it just the click of the key or is it turning over and not starting. If its click of the key check you battery cables and silenoid.
93 Ranger 4x4
Bilstein
Warn hubs
Rock Crawlers 15x8
33 M/T's
K&N
Skyjacker
Recovery gear
Warn 9.5ti on hitch carrier
Terra-Trax
www.californiapreparedness.net
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.5923 MB (Peak: 0.6455 MB) Data Comp: Off Server Time: 2026-06-09 21:43:56 UTC
